Home Technology Quantum Computing Is Emerging as a Tool for Tomorrow’s Electrical Grids
Tom Shindelman
Artificial intelligence and high-performance computing have helped electrical utilities modernize how they model, forecast, and manage grid operations. These tools already play a central role in maintaining reliability, balancing supply and demand, and planning new infrastructure.
But as electrical grids become more distributed, data-intensive, and renewable-heavy, some of the most complex decision-making problems are becoming harder to manage with existing approaches alone. Utilities are increasingly asked to coordinate variable renewable generation, battery storage, electric vehicle (EV) charging, distributed energy resources, extreme weather scenarios, and shifting demand patterns across vast networks.
Classical computing will remain essential to grid operations. In many cases, classical simulations, approximations, and optimization methods are highly effective, even for very large networks. The case for quantum computing is not that classical methods are collapsing. Rather, quantum computing may eventually enhance classical workflows in selected high-value areas where optimization complexity, scenario volume, and constraint density make better accuracy or faster exploration especially valuable.
That is why power systems are emerging as one of the most promising application areas for hybrid quantum-classical computing.
Where Quantum May Help Most
The strongest near-term case for quantum in electrical grids lies in optimization.
Many utility challenges require selecting the best, or a sufficiently good, solution from a large number of possible configurations. These include generation dispatch, unit commitment, optimal power flow, network reconfiguration, storage scheduling, EV charging coordination, infrastructure siting, and contingency-rich planning.
These problems often involve many interdependent variables: generators, transmission lines, storage assets, loads, voltage limits, weather conditions, reliability constraints, and market rules. Depending on the formulation, some of these optimization problems can become computationally difficult as the number of assets, scenarios, and constraints grows.
Today, utilities often manage this complexity with approximations, decomposed models, heuristics, and simplified assumptions. These methods are indispensable and frequently perform well. But they can also limit the number of scenarios considered, reduce model fidelity, or require tradeoffs between speed and precision.
Quantum computing could eventually help utilities explore larger solution spaces, evaluate more scenarios, or improve the quality of optimization results when used alongside classical solvers. The most promising applications are not routine grid simulations or generic data processing tasks, but complex optimization workflows where even incremental improvements in solution quality, speed, or scenario coverage could have operational and economic value.
A Hybrid Future for Grid Optimization
Quantum computers are not expected to replace classical computing infrastructure in grid operations. Instead, the more realistic path is hybrid computing: classical systems continue to perform the tasks they do well, while quantum algorithms are tested as accelerators or enhancement layers for specific optimization problems.
For example, a utility coordinating distributed energy resources may need to decide when to charge or discharge storage assets, how to manage EV charging demand, and how to dispatch flexible loads while maintaining grid stability. In another case, a transmission operator may need to evaluate many contingency scenarios to understand how outages, weather events, or generation shifts could affect network reliability.
These are the types of settings where quantum and quantum-inspired methods may prove useful. Quantum algorithms may help evaluate complex combinations of decisions under multiple constraints, particularly when the number of scenarios grows and when planners want to preserve more detail in the model rather than simplifying the problem too aggressively.
The value proposition is not guaranteed speedup across every grid problem. Some problems will continue to be solved efficiently with classical methods. Others may see only limited benefit. But in selected optimization-heavy use cases, especially those involving many scenarios, constraints, and possible configurations, quantum computing may offer a meaningful extension to the tools utilities already use.
Operational Use Cases Require Careful Framing
Grid operators also face challenges in fault detection, outage prediction, forecasting, anomaly detection, and sensor-data analysis. These areas are important, but they should be framed carefully in the context of quantum computing.
Unlike optimization problems, tasks such as anomaly detection, fault localization, load forecasting, and routine power-flow simulation do not yet have the same clear theoretical basis for quantum advantage. Quantum machine learning and quantum-enhanced data analysis are active research areas, and they may eventually contribute to better pattern recognition or forecasting workflows. But these applications remain earlier-stage and should not be treated as proven examples of quantum superiority.
A more defensible view is that these operational functions may benefit indirectly when paired with optimization. For instance, improved forecasting can feed into better dispatch decisions. Fault-risk models can inform contingency planning. Sensor data can support more accurate grid-state estimation, which then improves optimization quality.
In other words, quantum’s most compelling role is not necessarily in replacing classical forecasting or sensor analytics. It is more likely to emerge in the optimization layer that uses those inputs to make better decisions.
Improving Grid Efficiency and Resilience
Applied carefully, quantum and hybrid quantum-classical algorithms could eventually support several areas of grid modernization.
In power flow and dispatch, quantum-enhanced optimization may help operators evaluate more possible configurations while respecting physical and operational constraints. In storage management, it may help determine when and where batteries should charge or discharge to reduce congestion, stabilize supply, and improve renewable integration. In EV charging coordination, quantum methods may help schedule large numbers of charging events while minimizing local grid stress.
For planning teams, quantum may be especially useful in scenario-rich analysis. Utilities increasingly need to understand how networks behave under combinations of weather events, demand spikes, renewable variability, outages, and infrastructure changes. The ability to evaluate more scenarios with higher model fidelity could improve long-term planning, resilience investment, and risk mitigation.
These improvements do not require quantum to solve every grid challenge faster than classical systems. Even modest gains in optimization quality could matter when applied to high-value decisions involving energy losses, reliability, infrastructure investment, or market participation.
Real-World Progress
Quantum computing is no longer confined to theory. Energy companies, research institutions, and technology providers are already exploring early applications for power systems.
In France, EDF has worked with quantum technology company Pasqal to explore how quantum computing could support renewable energy forecasting and grid integration. Their work has examined variables such as temperature, wind, and solar radiation, as well as potential applications in optimizing EV charging schedules.
In Spain, Iberdrola has tested quantum methods for selecting optimal locations for grid-scale energy storage. This type of siting problem is a natural fit for optimization because it must balance cost, voltage control, network reliability, and infrastructure constraints.
Research organizations have also highlighted the growing body of work on quantum and hybrid algorithms for power-sector optimization, including optimal power flow, unit commitment, economic dispatch, and network topology optimization.
These examples are still early. They should be understood as proofs of concept and exploratory work rather than evidence that quantum computing is ready to transform grid operations today. But they show where the industry is focusing: optimization-heavy problems where better scenario exploration or more flexible modeling could produce practical value.
Market and Research Opportunities
Beyond grid operations, quantum computing may also contribute to energy markets and clean energy research.
Electricity markets depend heavily on forecasts, constraints, bidding strategies, and real-time supply-demand dynamics. Quantum-enhanced optimization may eventually help market participants evaluate more complex bidding or procurement scenarios, particularly when uncertainty from renewable generation and demand volatility increases.
In clean energy research, quantum simulation has a more direct theoretical foundation. Modeling molecular and atomic interactions is one of the areas where quantum computers are widely expected to become powerful over time. This could support research into battery chemistry, hydrogen fuel cells, photovoltaic materials, and other clean energy technologies.
These applications are distinct from grid optimization, but they are part of the broader energy-sector opportunity. As quantum hardware matures, the combination of quantum simulation for materials discovery and quantum optimization for grid and market operations could support a more flexible, efficient, and resilient energy system.
Next Steps for Utilities
Utilities do not need to wait for fault-tolerant quantum computers to begin preparing. The most practical first step is to identify which problems are suitable for quantum exploration.
Strong candidates include optimization problems with many variables, constraints, and scenarios. These may include storage scheduling, EV charging coordination, dispatch, unit commitment, optimal power flow, topology optimization, network reconfiguration, and infrastructure siting. Problems that are already well served by classical tools should remain with classical systems unless there is a clear reason to test alternatives.
Utilities can also begin with cloud-based quantum services and hybrid solvers, using pilot projects to benchmark quantum and quantum-inspired methods against existing classical approaches. The key is to evaluate performance rigorously: solution quality, runtime, scalability, robustness, and operational relevance all matter.
Internal education will also be important. Quantum computing has a steep learning curve, but software platforms are lowering the barrier by helping developers and analysts design, optimize, analyze, and execute quantum algorithms without needing to work directly at the physics level. Hardware-agnostic tools can help utilities experiment across multiple quantum backends while keeping workflows flexible as the technology evolves.
Quantum computing is not a silver bullet for electrical grids. It will not improve every simulation, every forecast, or every operational process. But for selected optimization-heavy challenges, it offers a promising path to augment classical methods, expand scenario analysis, and improve decision-making.
As grids become more dynamic, decentralized, and renewable-driven, the ability to make better decisions under complexity will become a defining capability. Quantum computing may become an important part of that future, not as a replacement for classical grid computing, but as a powerful complement where the problem structure justifies it.
—Tom Shindelman is a quantum application engineer with Classiq.
ExperiencePOWERlogo
Washington, D.C.
Register Now
