How accurate primary airflow measurements improve plant performance
Pages: 1234
The alchemy of burning any solid fuel-including coal-requires mixing fuel and air in just the right proportion at just the right time. Get the recipe wrong, and reduced efficiency and load rating will push your unit's production costs through the roof. Suboptimal fuel/air ratios also make combustors more likely to produce excessive levels of pollutants.
Inaccurate measurements that underestimate actual levels of primary air (PA) flow in a coal plant are particularly problematic, because higher-than-expected PA flow levels wreak havoc on more than just combustion efficiency and maximum unit capacity. Excessive PA levels also increase auxiliary loads and the operating costs of emissions-control systems; they may even make coal mills and pulverizers more prone to explosions. Because the causes and consequences of high PA flow (see box) are reasonably well understood, it is likely that your plant's general maintenance practices already address them. But it never hurts to review the details.
Pages: 1234
