Home Data Centers Five-Nines Data Center Uptime Starts with Automation
Ciaran Flanagan
Uptime has become the defining performance metric of the modern data center. As digital services underpin everything from financial markets to transport systems, tolerance for disruption has all but disappeared. For mission-critical environments, 99.999% availability and just five minutes of downtime per year aren’t the dream, but the baseline.
Industry performance is improving. According to the Uptime Institute’s Annual Outage Analysis 2025, data center service availability has increased for the fourth consecutive year. Yet despite this progress, high-profile outages continue to demonstrate how fragile uptime can be when resilience is applied unevenly. And in many cases, that unevenness stems from how different layers of infrastructure are designed and prioritized.
Last year, a power substation failure disrupted operations at London’s Heathrow Airport, stranding passengers and cargo. Separately, a major U.S. cloud outage impacted global platforms including communications, commerce, and entertainment services, affecting millions of users worldwide. These incidents underscore a persistent reality that even well-designed infrastructure can fail when a single weak point is exposed.
The Limits of Redundancy Alone
For decades, the industry’s primary response to uptime risk was duplication. The 2N model—two of every critical system—became the benchmark for high-availability facilities. Power, cooling, fire protection, and security systems were mirrored so that failure in one path could be absorbed by another.
This approach raised the baseline for reliability but wasn’t infallible. Incidents such as cooling failures at large colocation facilities have shown how faults can cascade across both primary and backup systems, halting operations even in environments designed for resilience.
In response, many operators have shifted toward more modular and value-engineered architectures, including N+1 and “four makes three” designs. These models maintain availability across defined failure scenarios while reducing capital expenditure and improving efficiency. At the workload level, availability zones, multihoming, and workload mobility now provide additional protection for end users.
However, shifting workloads during an incident does not eliminate the underlying vulnerabilities within individual facilities. It simply moves the problem elsewhere. Hardware failures persist, with Uptime Institute’s Annual Outage Analysis 2025 continuing to identify power-related issues as a leading cause of major outages. These failures are often rooted in equipment fatigue, design limitations, or operator error.
The Overlooked Layer in Uptime Design
Across all models, from 2N to N+1, a critical vulnerability persists: In many data centers, the control and automation layer is not designed with the same level of redundancy as the mechanical and electrical systems it governs.
This is a significant blind spot. Control systems orchestrate the entire facility, monitoring conditions, coordinating responses, and providing operators with the visibility required to make informed decisions under pressure. When that layer is single-threaded, even the most robust physical redundancy can be undermined.
Even a minor component failure can quickly lead to partial or complete loss of operational visibility, with alarms delayed, misinterpreted, or missed altogether. At exactly the moment when clarity matters most, operators are forced into greater levels of manual intervention, managing highly complex environments with reduced situational awareness. In any high-reliability industry, that is an unacceptable risk.
Why Automation Must Come First
An automation-first approach reframes how uptime is achieved. Rather than treating controls as a supporting element added late in the design process, automation becomes the foundation on which reliability is built.
Well-designed control systems provide the stability required to operate complex infrastructure at scale, while intelligent automation builds on that foundation to deliver both reliability and efficiency. By coordinating subsystems, enforcing consistent operating logic, and reducing reliance on manual intervention, automation also helps mitigate human error.
Automation adds intelligence to infrastructure and enables real-time situational awareness across power, cooling, and environmental systems. Instead of isolated data points, operators gain a unified view of the facility, supporting faster and more confident decision-making.
As automation evolves, its impact on uptime becomes more pronounced. Advanced analytics, artificial intelligence (AI), and machine learning can continuously assess operating conditions, identify emerging risks, and predict failures before they occur. This shifts operations from reactive response to proactive intervention.
This is the software dimension that is often missing from five-nines discussions. Automation is not a convenience layer or an efficiency add-on, but the operational intelligence that keeps complex environments stable under stress.
Designing Resilience into the Control Layer
Achieving consistent five-nines performance requires redundancy at the control and automation level, not just in mechanical and electrical systems. That means resilient control architectures, redundant communication paths, and fault-tolerant integration across electrical power monitoring systems and building management systems.
Standardized reference architectures, such as those developed by infrastructure providers like Siemens, are increasingly important in this context. They reduce design risk, accelerate deployment, and ensure alignment with international standards. More importantly, they embed resilience into the systems that operate the facility day-to-day.
When automation and controls are treated as critical infrastructure rather than secondary systems, uptime becomes more predictable. Operators gain confidence not only that systems will fail gracefully, but that they will have the visibility and control needed to respond effectively when they do.
Intelligent Automation for Modern Data Centers
The operating environment for data centers is becoming more complex, not less. Aging grid infrastructure, the volatility introduced by AI-driven workloads, and the growing integration of renewable energy sources are all increasing operational risk. At the same time, expectations for availability continue to rise.
Five-nines uptime can no longer be achieved through hardware redundancy alone. It requires intelligent, resilient automation that continuously monitors, anticipates, and responds to system-level changes in real time. At five-nines scale, an automation-first design is the foundation for delivering the level of resilience modern digital infrastructure demands.
—Ciaran Flanagan is vice president and global head of Data Center Solutions and Services at Siemens.
