Detecting and solving lube oil varnish problems
Pages: 12345
Autodegradation is a phenomenon that plagues gas turbines, particularly large frame units. Once the additives in turbine oil deplete, the oil becomes saturated with soluble soft contaminants. As the oil cools, the contaminants come out of solution and form varnish deposits. The contaminants' solubility at turbine operating temperatures renders electrostatic and agglomeration technologies useless for eliminating varnish problems in these applications (Figure 1).
1. Go with the flow chart. These are the key mechanisms of varnish deposition from gas turbine lube oil. Source: EPT Inc.
Although several commercial products claim to solve the lubricant varnish problem, good operating practices remain the first line of defense (see box). The vendors' claims are valid for many applications, but not for modern large frame gas turbines. The problem only gets worse when gas turbines are cycled or used for peaking service, as so many are today.
Pages: 12345
