The challenge Spanish regulators face is balancing their country’s energy needs (now growing at 5% a year) and keeping Spain’s carbon emissions promises under the Kyoto Protocol. Their solution for keeping the lights on in the fifth-largest electricity market in the EU is born of necessity and immensely practical: build natural gas–burning, high-efficiency combined-cycle plants and significantly increase Spain’s wind power portfolio. Adding more coal plants was just not in the cards, given Kyoto and a government actively working to close coal mines. In Spain, the use of coal for power generation has dropped almost 50% over the past two decades.
Spain began shifting from coal to natural gas as the preferred fuel for baseload capacity in the mid-1990s even though the country must import all of ifs gas, either by pipeline (from one offshore field operated by Repsol-YPF) or as liquefied natural gas (LNG). Spain is Europe’s second-largest LNG importer (after France) and relies on Algeria for over 60% of its total. Spain leads the EU in growth of natural gas consumption; that growth is projected to continue at a rate of about 10% a year through 2011.
Spain, the world’s second-largest producer of wind power (Germany is No. 1), also has invested heavily in that technology. Over 10,000 MW now is on-line—one-sixth of the world’s total at the end of 2005—satisfying 6% of Spain’s total electricity demand. Another 57,000 MW of wind projects are on the drawing board. Comparatively, the U.S. is an also-ran with a mere 9,000 MW in operation at the end of 2005.
Madrid-based Iberdrola Generación S.A. (Iberdrola), the largest owner and operator of renewable energy facilities in the world, expects to hit 6,200 MW of installed wind capacity by 2008 as part of its plans to build over 10,000 MW of capacity fueled by renewable energy sources worldwide by the end of 2011.
Spanish armada
Close to Arcos de la Frontera, in the southern Spanish province of Cádiz, Iberdrola recently placed into commercial service the Group III 800-MW power block, featuring two General Electric (GE) Frame 9FB gas turbines (Figure 1). The project began six years ago with the acquisition of a 400-MW combined-cycle plant under development by Abengoa Group. That was followed by the purchase of a 1,200-MW project being developed by an Enron subsidiary. By early 2003, Iberdrola was granted permission to construct the 1,600-MW Arcos de la Frontera (Arcos) plant. At an estimated cost of 800 million euros (about $1 billion at current conversion rates), Arcos (Figure 2) is the largest and most expensive power plant Iberdrola has built in its 100-year history.
1. First in line. The newest member of General Electric’s gas turbine stable is the Frame 9FB, shown here in one of the two Arcos de la Frontera Group III power blocks. Courtesy: Iberdrola
2. Reign in Spain. Iberdrola commissioned the 800-MW Arcos III power block last December, making the 1,600-MW combined-cycle plant the largest of its kind in Spain. Courtesy: Iberdrola
Phase A (consisting of Arcos I and II) went into commercial service in 2004. During that year, Iberdrola also started up the 400-MW Santurtzi combined-cycle plant, for an annual total of 1,200 MW. Phase B of the Arcos III plant and a 400-MW plant in Aceca, Toledo, added another 1,200 MW of combined-cycle muscle to Iberdrola’s portfolio the following year. If the 800-MW Escombreras plant is commissioned this year as expected, Iberdrola’s total increase in combined-cycle capacity over the past three will be a whopping 3,200 MW.
Atlanta-based General Electric was responsible for the design and supply of the major rotating equipment for each of the Arcos power blocks. Iberdrola’s engineering group, Iberinco (Iberdrola Ingeniería y Construcción), was responsible for the integration engineering, project management, and turnkey supply of the balance-of-plant equipment. Spain’s Sener provided engineering support to this project.
Introducing the 9FB gas turbine
Unique configuration
Both Arcos I and II have a common driveline for the gas turbine and steam turbine, which drive a common generator from opposite ends. Such a 1×1 configuration is rare in the U.S. Each of the identical 400-MW (nominal) units (Table 1)—which produce in parallel—has a GE 9FA gas turbine rated at 248 MW (see box), an NEM heat-recovery steam generator (HRSG), and a GE D10 steam turbine rated at 136 MW. Two Alstom-supplied condensers sit under the steam turbine, whose drivelines are enclosed in a common building with the air inlet filter house mounted on the roof. The HRSGs are located outside the building. An auxiliary boiler supplies start-up steam. Arcos I and II use liquid fuel (with a maximum sulfur content of 0.2%) as backup.
Table 1. Combined-cycle performance at Arcos I through III. Source: Iberdrola
Arcos III, which is configured as a more-familiar 2 x1 800-MW power block, is the first commercial host of two GE 9FB turbines nominally rated at 259 MW apiece (Figure 5), two NEM multi-pressure HRSGs, and one 295-MW GE D11 steam turbine (Figure 6). In GE vernacular, this configuration is called a STAG (STeam And Gas) 209FB. Initial baseload operation was reached in late November 2005. The entire plant is designed for baseload operation (operation at full load for 8,500 hours a year). The output of Arcos III travels through a 400-kV substation at the plant to Red Eléctrica, Spain’s national grid operator.
6. Four-footers. The D11 steam turbine features 48-inch last-stage blades. Courtesy: Iberdrola
The steam turbine has a single high-pressure/intermediate-pressure (HP/IP) section and one dual-flow low-pressure (LP) section with control and shutoff valves for each of the three sections. The HP steam supply is at 1,800 psia and 1,050F, and the exhaust pressure is 1.73 inches Hg. The HP and IP stages have a bypass system, enabling steam to be desuperheated before entering the condenser. The bypass system activates whenever pressures fall to a predetermined setpoint and also during start-up and low-load operation to provide more operating flexibility. The D11 steam turbine is fitted with GE’s new 48-inch last-stage blades.
The plant’s distributed control system (DCS), located in the control room, handles overall plant control functions (via start-up, shutdown, and emergency operation signals), monitors field instrumentation, and controls auxiliary systems (Figure 7). Turbine controls for Arcos III, also in the control room, are provided by a triple-redundant GE Speedtronic Mark VI system. It directly controls and monitors the gas turbines, steam turbines, the three GE 330H generators (rated at 330/360 MVA), and other plant auxiliaries. The turbines are controlled by the Mark VI via a communications link with the DCS.
7. Unified controls. Controls for the three power blocks are integrated in a single control room. Courtesy: Iberdrola
Iberdrola elected to construct a single building to house the control room and monitoring systems for the entire plant, as well as offices, shops, and storerooms. Three other buildings house the water treatment, compressed-air, fire protection, and other balance-of-plant systems.
Cooling water for the entire plant comes from the Guadalcacín II reservoir adjacent to the plant. Two mechanical-draft, counterflow cooling towers (Figure 8) with eight cells apiece cool circulating water. Exhaust gases are released to the atmosphere through twin 200-foot stacks.
8. Keeping cool. Arcos III uses cooling towers to cool condenser water. Shown are the cooling water pipes to the condenser. Courtesy: Iberdrola
Exceeding goals
Performance of the plant since commercial operation commenced has been exceptional, surpassing contract performance (Table 2) and emissions limits (Table 3) with room to spare. As of July 1, Unit 3 (Arcos III, gas turbine 1) had accumulated 1,968 fired hours and 92 starts. Unit 4 had 2,285 fired hours and 75 starts.
Table 2. Performance test results of Arcos III, corrected to ISO conditions. Source: Iberdrola
Table 3. 9FB emissions test results at Arcos III. Data are based on two 24-minute tests at part load and three 64-minute tests at baseload for each unit. All data shown are corrected to [email protected]% O2. Source: Iberdrola
