July marks two important milestones that set gas-fired generation on its course to becoming a dominant form of power generation: commercial operation of the world’s first industrial gas turbine in Neuchâtel, Switzerland, in 1939, and commercial operation of the first gas turbine in the U.S. used to generate electric power—a 3.5-MW General Electric (GE) unit at the Belle Isle Station in Oklahoma City in 1949.
GE, which today is the largest original equipment manufacturer in the gas turbine space, has since developed and deployed several generations of gas and steam turbines, generators, heat recovery steam generators (HRSGs), condensers, and other balance-of-plant equipment. Here is how GE’s modern gas turbine model portfolio has evolved over the past 80 years.
[For more, see this exclusive interview with GE Power Chief Technology Officer John Lammas: “The POWER Interview: What Drove the Gas Turbine Technology Leap at GE Over the Past 70 Years.“]
1939 The World’s First Industrial Gas Turbine Starts Commercial Operation
The world’s first industrial gas turbine set, a 4-MW simple cycle gas turbine, operates at full power for the first time at a municipal power station in Neuchâtel, Switzerland, on July 7, 1939. The turbine is designed by Brown Boveri & Cie (BBC), a company that was established in 1891 in Baden, Switzerland, but merged with ASEA AB in 1988 to form ABB (ASEA Brown Boveri), and then sold as part of ABB’s power generation business to Alstom in 2000. GE acquired Alstom’s power business in 2015.
The Neuchâtel Gas Turbine goes into commercial operation as a standby unit with an efficiency of 17.4%. The turbine rotates at 3,000 rpm, has a turbine inlet temperature (TIT) of 550C (1,022F), and provides 15,400 kW, of which 11,400 kW is absorbed by the compressor with an air inlet temperature of 20C (68F). Used primarily for standby and peaking duties, it operates for nearly 70 years.
1949 America’s First Power Generating Gas Turbine
GE’s first gas turbine, a 3.5-MW machine that is installed at a separate building attached to a 51-MW steam unit at Oklahoma Gas and Electric Co.’s Belle Isle Station, begins delivering power. The gas turbine is arranged with its axis horizontal. As the American Society of Mechanical Engineers (ASME) notes, “although this unit was rated at 3,500 kW, it actually exceeded this output in service by a wide margin. It often provided an electrical output of 5,000 kW, and between July 1949 and July 1952 the average output was 4,200 kW.” The GE Frame 3 unit reportedly had an efficiency of about 17%. Notably, however, in addition to generating power, its exhaust gas was also used to heat feedwater for the conventional steam plant—making it the nation’s first gas turbine used in “combined cycle” configuration.
1951 A Two-Shaft Derivative
GE installs three 5-MW gas turbine power plants in Rutland, Vermont, based on a two-shaft derivative of the Frame 3. The so-called “kilowatt machines” include twin intercoolers and recuperators.
1953 First Commercial Intercooled Recuperated Gas Turbine with Reheat
Technology breakthroughs in cycle pressure ratio, materials, and coatings that follow the Neuchâtel unit enable BBC to boost turbine inlet temperatures to 1,200F, and in 1953, the company starts up the 27-MW Beznau II plant, boosting thermal efficiency of the two-unit 40-MW Beznau power plant in Switzerland to 30%. BBC engineers of the two-shaft Beznau turbine squeezed “every bit of efficiency from the Brayton cycle with limited cycle pressure ratios and cycle maximum temperatures,” wrote S. Can Gülen in his February 2019-released book Gas Turbines for Electric Power Generation. “The end result was a whole power plant instead of a compact engine in a skid.”
1960 First Commercial CCGT
Encouraged by new gas discoveries in the Netherlands, NEWAG, an Austrian utility, puts into service Korneuburg-A, a 75-MW combined cycle plant—one of the first of its type to be built in Europe. The plant consists of two 25-MW BBC Type 12 turbines, a 25-MW steam turbine, and a HRSG with supplementary firing. Despite its low efficiency (of about 32.5%), the unit operates at baseload from 1960 to 1975, with an average of 6,000 hours per year, but it soon becomes uneconomical to operate, mainly owing to fuel costs and better efficiencies at coal plants, which came online in Europe from 1965 onward, and is thereafter used mostly for peaking duty.
1967 First Dedicated GE Combined Cycle Plants
In the aftermath of the Great Northeast Blackout of November 1965, regulatory mandates force utilities to increase system reserve margins by installing a certain percentage of smaller, localized, fast-start generating units with black-start capabilities. GE installs an 11-MW FS3 in the City of Ottawa, Ontario, and a 21-MW FS5 at Wolverine Electric Ottawa, also in Ontario. The FS3 had already been tested in U.S. maritime vessels and in locomotives, noted Ronald Hunt, a consulting engineer who is part of the Institution of Diesel and Gas Turbine Engineers (IDGTE), in his April 2019-released book The Development and History of the Gas Turbine for Power Generation, Industrial, and Marine Purposes.
1968 First LM Turbine
GE engineers reconfigured the J79 turbojet, an aircraft machine that was first flown in 1955, as the LM1500, a turbine with industrial and marine uses. The first LM1500 is a 13.3-MW turbine installed at the Millstone nuclear plant in Connecticut.
1969 More Sophisticated Aeroderivatives
The first LM2500, derived from the CF6-6 flight engine, powers the U.S. Navy’s GTS Adm. Callaghan cargo ship. The turbine uses a 16-stage compressor section with inlet guide vanes and 6-stages of variable stator vanes, with a two-stage high-pressure turbine section exhausting into a 6-stage free power turbine. The original design had twin-shaft HPT blades and an ISO power rating of 17.9 MW and a 35.8% simple cycle thermal efficiency. LM2500 turbines are still widely in use today. “To this day, the U.S. Navy continues to select the LM2500 to power the latest surface combatants in its fleet,” GE says.
1970 Frame 5 Gets Bigger
Sales of the Frame 5, a single- and twin-shaft, simple cycle, axial-flow turbine, remain brisk. In 1970, an aluminum smelter in Bahrain employs a Frame 5 unit with 24-MW rating. The model has today acquired a venerable status in the gas turbine world because of its reputation as a reliability workhorse. As Dave Lucier, who managed GE’s field engineering program, noted some years ago, a black-start Frame 5 in Southampton, New York, initiated the restoration of power on Long Island, and eventually New York City, following the Great Northeast Blackout on Nov. 9, 1965. “The future is nothing without the past,” he remarked.
1970 Frame 7 Appears
The MS7000, a Frame 7 (60 Hz) turbine, appears, rated at 47.2 MW with a TIT of 1,650F. GE soon after begins developing the 50-Hz Frame 9 single-shaft machine with Alstom.
1970 BBC Launches the GT Series
To compete for market share in the upturn for gas turbines in the aftermath of the blackout, and responding to GE’s strategy to build larger gas turbine units, BBC develops the GT11 (60 Hz) and GT13 (50 Hz) families. BBC’s first GT11 gas turbine is ignited at Rainbow Lake in Canada in 1970. It is rated at 32 MW at 3,600 rpm.
1971 First E-Class Turbine
The first E-class (a 7E) is debuted at National Grid’s Shoreham Combustion Turbine plant in New York.
1972 First 7B
GE introduces the MS7001B, the first Frame 7 B-class turbine, rated at 51.8 MW.
1975 First Frame 9
The first 80.7-MW Frame 9B machine is installed by EDF near Paris, for mainly peaking duty.
1978 First 6B
The first 6B machine is installed at Montana-Dakota Utilities’ Glendive station. The turbine is still in operation, said GE Gas Power CEO Scott Strazik in September 2018. Another 1,150 6B turbines are installed across the world, powering energy production facilities and industrial applications in segments such as petrochemical, oil and gas exploration, and cement production, GE noted. Over the years, the company has improved the technology. In 1981, it developed technology to increase firing temperatures, leading to 15% more output. In 1991, it introduced dry low-NOx combustion technology, and in 2009 it introduced a performance improvement package featuring advances in materials, coatings, sealing, and aerodynamics derived from its F-Class line. To mark the 40th anniversary of the installment, GE in 2018 also unveiled a 6B fleet repowering solution as part of an effort to continue investing in its “mature fleets” to keep them competitive.
1984 Dry Low-NOx Breakthrough
The first commercial operation of first-generation BBC-developed “lean” dry low-NOx (DLN) premix combustion begins at a modified GT13D unit at the 420-MW combined cycle Lausward plant in Dusseldorf, Germany. As Dietrich Eckardt notes in his 2014-published book Gas Turbine Powerhouse, BBC presented the concept in 1978 based on theoretical insight that effective low-NOx combustion required the separation of fuel/air mixing from the combustion process and that combustion itself should take place under “lean” conditions. The technology lowered the unit’s NOx emissions to 32 parts per million (ppm). Although it was later applied to seven GT units, it was “too complex and prone to deterioration after a while,” which is why BBC began development of a second generation of lean premix burners, said Eckardt.
1985 Cogeneration Milestone
Two GE LM2500 aeroderivative gas turbines, a steam turbine, and a generator mounted in a single-shaft configuration are installed at a district heating system owned by IJsselcentrale in the Netherlands. The configuration is designed to offset the high investment cost of the LM2500 gas turbines. GE notes the project also marked its first steam injection system application. Performance tests show a full-load efficiency of 50%.
1987 First GT13E Launched
The first ABB (later Alstom, and then GE) GT13E—a 147.9-MW unit—is successfully commissioned at the Hemweg facility, owned and operated by Dutch utility UNA, in the Netherlands. Another 27 units of this type were put into operation before market demands push the company to develop gas turbines with higher efficiencies and NOx emissions below 25 ppm. In 1991, it launches the GT13E2. The turbine uses a single, top-mounted SILO combustor.
1988 LM6000 Launched
GE expands the LM fleet to include the LM6000, a turbine that is derived from GE’s CF6-80C2 high bypass turbofan aircraft engine. The simple cycle, two-shaft, high-performance gas turbine has a capacity of up to 36.6 MW and an efficiency of 41.9% at the ISO rating point.
1990 The F-Class Era Begins
The first F-class machine, a 147-MW 7F with a TIT of 2,300F, began operating at Virginia Electric & Power Co.’s (VEPCO) Chesterfield Power Station on June 6, 1990. While the prototype was initially used for simple cycle testing before it was converted to combined cycle in 1992, sources widely report that it had an efficiency of 45.2% and a total power output of 214 MW in combined cycle mode (and 150 MW and 34.5% in simple cycle mode). According to the 7F Users Group, Chesterfield 7 marked the beginning of the golden era for gas turbine technology (which ended in 2015, according to some industry observers). The group also points out that F-class machines have grown “in complexity over the years to satisfy ever more demanding environmental regulations and owners’ goals of higher efficiency and availability/reliability.”
GE notes F technology was initially designed in the 1980s, when it represented “a quantum leap in the operating temperatures, cooling technology and aerothermal performance of heavy-duty gas turbines.” Since GE introduced the the MS7001F in 1987, a design driven “by the demand for higher efficiency plants with lower emissions and lower cost (per kW/hour),” the technology has been scaled upward and downward, and it is today available in outputs ranging from 51 MW for a 6F.01 simple cycle plant to more than 1,000 MW for a 3×1 7F.05-based combined cycle plant. The family has expanded to 6Fs and 9Fs. More than 1,500 F-class machines have been installed worldwide, with applications that range from power generation, combined heat and power, and mechanical drive applications, in industries as diverse as aluminum smelting, refineries, and food processing.
1991 Commercial Dry Low NOx Solution
While GE began developing and testing dry low-NOx (DLN) combustion systems in the 1970s, it introduces its first commercial DLN combustion systems for gas and heavy-duty gas turbines in 1991. Research efforts yield the DLN-1 solution for E-class turbines, and the DLN-2 solution for F-class turbines; the latter has also been applied to EC and H-class machines. In 2015, GE introduced a DLN2.6+ combustion system for new and existing 7F gas turbines, and in May 2018 it announced a “flex” upgrade solution, which combines the DLN 2.6+ combustor with axial-fuel-staging technology. Earlier this year, the company said it completed the first installation of a new gas-fired power plant technology that can reduce NOx to 5 ppm.
1992 The First 9F
A 159-MW 7F with a 2,350F TIT begins operating at another Chesterfield unit (Chesterfield 8) in Virginia, and the first 9F begins operating in simple cycle mode at an EDF site in northern Paris. GE jointly developed the 212-MW turbine with Alstom.
1992 The GT13E2
ABB introduces the 166-MW GT13E2 gas turbine to the market. Compared to the GT13E, the GT13E2 has a higher TIT of 2,012F and increases the compressor ratio from 13.9:1 to 15.0:1. GE still offers the turbine model today. The GT13E2 2017 delivers 210 MW with 38% simple cycle efficiency and more than 55% combined cycle efficiency, it says.
1996 Power Plant on Wheels
GE unveils the TM2500, a trailer-mounted portable aeroderivative—a “power plant on wheels.”
1997 F-Class Competition Yields the GT24/GT26
GE’s introduction of the 150-MW Frame 7F—the first F-class model—in 1987 was quickly followed by Westinghouse (in collaboration with Mitsubishi) in 1989 with the 501F, and then in 1991 by Siemens with its V94.3. That’s why, Eckardt notes, ABB “decided for a ‘leap frog’ strategy to position itself to catch up with its competitors.” The company launched its own GT24 (60 Hz)/GT26 (50 Hz) in December 1991. A 165-MW GT24 prototype was installed at the Gilbert power plant in New Jersey in 1993. “Presented as a revolutionary solution, it was the most compact model available on the market and the only one to use sequential combustion with a particularly high compression ratio,” he notes. It also had an efficiency of 56%, which was 2% to 3% more than its competitors. The GT26 was launched in 1997. The 770-MW Rocksavage gas-fired power station in the UK is one of the first to be equipped with GT26 gas turbines.
2003 The H-Class Era Begins
GE unveils the first H-class system (H-System), 9H, a 50-Hz 480-MW turbine, with firing temperatures of 2,600F, at Baglan Bay Power Station in Wales. The 9H—a single-shaft combined cycle plant—achieves a firing temperature well above 2,600F. But as Gulen notes in his February 2019 book, while the H-System “was an unqualified success from a technology perspective, it was a commercial failure.” Single-crystal, hot-gas-path components with advanced thermal barrier coatings added to the cost and complexity with longer-than-typical major maintenance outages, he notes. Altogether, only six H-System combined cycle power plants were built and continue to operate commercially, and while one of those plants—the 60-Hz Inland Empire Energy Center—has achieved notable heat rate and NOx emissions parameters, GE does not offer the H-System anymore. The newest stars of its H-class lineup are its HA models.
GE’s launch of the H-System, however, heated up competition among major manufacturers in the large gas turbine space, who doubled down on efforts to boost gas turbine efficiency. In 2011, Siemens broke the 60% thermal efficiency barrier with its 8000H gas turbine in Irsching, Germany, a gas turbine that nominally had the same TIT as the H-System (2,732F), but a lower firing temperature. Westinghouse, meanwhile, pursued the intermediate G-class firing temperature in collaboration with Mitsubishi Heavy Industries (MHI)—technology that is now offered by Mitsubishi Hitachi Power Systems (MHPS). MHI also dropped development of H technology and began development of the J-class, whose combustor technology is based on the steam cooling system used in the G-class.
2005 The 6C Takes Root
A 130-MW 2x Frame 6C (6F.01) CCGT is debuted in Turkey. The 6C, which is now known as the 6F.01, was originally introduced in 2003 at 42 MW and upgraded to 46 MW after site validation. GE says this model leads the industry for cogeneration and combined cycle efficiency for gas turbines with an output range of less than 100 MW. “Its tremendous exhaust energy allows the production of a high quantity of steam for either power generation or cogeneration. It achieves over 58 percent efficiency in 2×1 combined-cycle arrangement, and more than 80 percent efficiency in cogeneration operation,” it says.
2009 Alstom’s MXL2 Upgrade
Alstom rolls out its GT26 MXL2 advanced gas turbine upgrade at Castejon power plant in Spain. The MXL upgrade allows GT26 owners to benefit from new optimizations to the compressor, and coating and cooling improvements in the HP and LP turbines. It also extends the life of equipment. While the MXL concept began as a standard feature of the newer GT13E2 fleet, Alstom also installed the first MXL2 upgrade for its GT13E2 gas turbine at the South Humber Bank Power Station in the UK in 2012.
GE today offers the MXL2 upgrade in its GT13E2 turbines, which it acquired from Alstom in 2015. As part of the Alstom acquisition, however, GE agreed with the European Commission to divest a part of Alstom’s gas turbine portfolio to preserve competitiveness. The divestment included, in general, Alstom’s GT26 and and J-class GT36 gas turbine technology and some of the GT26 services contracts, all which were sold to Ansaldo Energia. Nevertheless, GE retained all GT24 services contracts. Ansaldo today offers the MXL2 upgrade for the GT26, and GE packaged the upgrade in a new offering, the GT26 HE, which it rolled out in 2019. Ansaldo today offers the MXL2 upgrade for the GT26, and GE packaged the upgrade in a new offering, the GT26 HE, which it rolled out in 2019.
2014 GE Launches the HA Line
Marking a major new milestone, GE introduces two new air-cooled H-class turbines, the 9HA (50-Hz) and 7HA (60-Hz), which are developed through advancements in materials, aerodynamics, and advanced manufacturing. The turbines also incorporate the benefits of the new digital era where integrated software and analytics drive greater performance and efficiency. GE says the turbines, which range from 290 MW (7HA.01) to 571 MW (9HA.02), will break records for efficiency.
2015 GE Acquires Alstom’s Power Business
Following regulatory approval of a $10.6 billion transaction in more than 20 countries and regions, GE’s acquisition of Alstom’s energy activities is completed in November 2015.
The deal is GE’s biggest transaction ever. Jeff Immelt, who was then GE’s CEO, said GE’s acquisition of Alstom’s complementary technology, global capability, installed base, and talent meant immediate benefits for customers, including for current projects using GE 7HA gas turbines and Alstom’s HRSGs and steam turbines. It is also a boon for a number of proposed projects. In November 2017, however, another former GE CEO, John Flannery, revealed that Alstom had “clearly performed below our expectations.” GE bought the French company for four reasons: its installed base; a broad product line in steam and power islands, which GE anticipated it could cross-sell; synergies across operations, costs, and revenues; and the talent of Alstom’s personnel, which ultimately paid off. But GE was hurt by a “market clearly dramatically lower than what we underwrote in that business,” Flannery said.
2016 First HA Deployed
The first 397-MW 9HA.01, with an efficiency of 62.22%, deploys at EDF’s Bouchain plant in France. The project is a POWER Top Plant in 2017 .
2017 LM9000 Launched
As market demand for aeroderivatives picks up to help balance the growing shares of renewables, GE introduces the LM9000, a 67-MW to 75-MW power plant derived from the GE-90 aircraft engine, which is fitted on a Boeing 777.
2017 6F.01 Relaunch for Distributed Market
To gain some clout in the surging distributed energy market, GE relaunches the 6F.01 turbine, outfitting it with advanced materials and technologies adopted from GE’s H- and F-class gas turbines. The relaunched model is first installed at the Huaneng Guilin Gas Distributed Energy Project. The 50-MW 6F.01 at that project boasts a combined cycle efficiency of 57% and fuel utilization rate of 81.15%.
2017 7HA.02 Deployment Milestone
Exelon’s Wolf Hollow and Colorado Bend projects in Texas debut the 7HA.02 turbine. Both plants are configured as 2×1 multi-shaft with total plant output greater than 1,000 MW at each site.
2017 First 7HA.01 Turbines Begin Operation
GE and Toshiba collaborate to install six 7HA.01 gas turbines and two steam turbines at Chubu Electric Co.’s Nishi Nagoya thermal power plant in Aichi Prefecture, Japan. The first block of three units reached commercial operation in September 2017. Block 1 has achieved a gross combined cycle efficiency level of 63.08%, which sets another world record for highest gross efficiency. The second block of three units reached commercial operation at the end of March 2018. The project was a POWER Top Plant in 2018 .
2018 Dual-Fuel HA
In June 2018, PSEG Power, a subsidiary of PSEG, begins commercial operation of its Sewaren 7 combined cycle power plant in New Jersey. The 540-MW unit, a 7HA.02, is the first dual-fuel H-class turbine in the world. The plant is designed to operate on two types of fuel, including natural gas and ultra-low-sulphur distillate (ULSD) fuel oil. The dual-fuel capability enables the use of ULSD in the event of a shortfall in natural gas supply, increasing the plant’s dependability and reliability.
2019 First 9HA.02 Shipped
GE’s largest HA turbine to date—the 571-MW 9HA.02—is shipped to Southern Power Generation Sdn Bhd (SPG) for its new Track 4A plant, a 1,440-MW combined cycle power plant in Pasir Gudang, Johor, Malaysia. It will consist of two generating blocks, each equipped with a 9HA.02 gas turbine, generator, and HRSG from GE.
2019 GT26 HE Launched
GE introduces the GT26 High Efficiency (HE) upgrade, blending GE and Alstom technology, to cater to high renewables penetration. Uniper will install the turbine at the Enfield Power Station in the UK in 2020. “If you think of upgrades that we’ve done in the past, they’ve been what I would say, piecemeal, either a hot-gas-path AGP [advanced gas path] that you may be aware of, a combustor, or a compressor. With the HE—the high-efficiency upgrade—we are actually hitting every module. We’re looking at the LP [low-pressure] turbine, the compressor, and the combustor,” Amit Kulkarni, general manager for the F/H-class product line organization within GE Power Service, told POWER in March 2019. “So, it’s the most-advanced upgrade for this model, and it blends technologies from both F as well as our HA class units. It also combines technology and expertise with both GE and Alstom.”
2019 7HA.03 Unveiled
GE unveils the 7HA.03, the newest model in its 2014-launched high efficiency air-cooled (HA) gas turbine line. The company also announces that Florida Power and Light’s (FPL’s) Dania Beach Clean Energy Center will be the first to showcase two of the “world’s largest, most efficient, and flexible gas turbines” for the 60-Hz market when they begin commercial operation in 2022. The 7HA.03 will have a single-cycle net output of 430 MW—a sizable boost compared to its forerunner, the 7HA.02, which is rated at 384 MW, and the first-generation gas turbine in the HA class, the 7HA.01, which is rated at 290 MW. In combined cycle, a 1×1 7HA.03 plant could offer 640 MW, and in 2×1, 1,282 MW. Because it integrates the latest advancements in manufacturing technology, and benefits from refined technology from previous models, the 7HA.03 will have a net combined cycle efficiency of 63.9%, which is a 0.4 percentage increase over its forerunner, the 7HA.02, GE said.
2020 GE Advocates for Power Sector Decarbonization
In a wide-ranging December 2020–published white paper, GE formalizes its “all-in” stance to combat climate change. The white paper argues that decarbonization of the power sector—which it defines as “the reduction of carbon emissions on a kilogram per MWh basis”—and electrification of energy use sectors is “mired in defining and debating an ideal future state and the timeline by which society would achieve that end-state.” It concludes that even as efforts continue to advance technologies for low or near-zero-carbon power generation, the world should quickly and strategically deploy a combination of renewables and gas power—a concept it terms “renewables + gas power”—as the “most effective near-term actions” to decarbonize the energy sector.
In the paper, GE highlights a trajectory for the future of gas power in a decarbonized power system. “In the near-field, it’s one-third, roughly, the emissions of the installed base for coal. Over the mid-term, our gas turbines and the world’s gas turbines, for the most part, can run on doping hydrogen [using a hydrogen/natural gas mix],” an executive told POWER. “In the far-field will be carbon capture and sequestering, as well as 100% hydrogen for gas plants.”
2021 First 9HA.02 Turbines Begin Commercial Operation
GE begins commercial operation of the first two 9HA.02 turbines—one of the largest gas-fired power generating models in the world—at the 1.4-GW Track 4A power plant in southern Malaysia. The 9HA.02, rated at 575 MW under ISO conditions, pushes net efficiency “beyond 64% combined cycle efficiency.” The 9HA.02 also integrates advances in additive manufacturing and combustion breakthroughs like its DLN (dry low-NOx) 2.6e combustor with axial fuel staging (AFS), which enables lower nitrogen oxide emissions with improved turndown. The combustion system incorporates an evolutionary improvement to the premixing fuel nozzles, a technology GE developed in collaboration with the U.S. Department of Energy to “deliver a step-change improvement in performance, emissions, and fuel flexibility,” GE told POWER.
Track 4A, now known as the Sultan Ibrahim Power Plant, is POWER’s 2021 Plant of the Year. In February 2022, Edra Melaka Power Plant (EMPP), a three-block 2.2-GW CCGT plant owned by Edra Power Holdings Sdn. Bhd., began commercial operation in Alor Gajah, Melaka State—becoming the world’s second 9HA.02 CCGT project. A third 1.4-GW 9HA.02 project at Bang Pakong in Thailand was completed in September 2022.
2021 GE Announces Power Group Spinoff
GE in November 2021 announces plans to split the historic conglomerate into three separate investment-grade companies focused on healthcare, energy, and aviation. The effort, focused on debt reduction, effectively creates a stand-alone energy business, which combines its GE Power, GE Renewable Energy, and GE Digital business segments. The company tells POWER the move aligns with customer decisions to decarbonize, and that “asset-balancing decisions can best be solved with [an] integrated top-of-the-house approach.”
2022 Pioneering Hydrogen Combustion at Major HA-Class Project
Efforts to transition the GE 7HA.02 gas turbines to hydrogen combustion begin. A test to combust an initial blending of 5% hydrogen and 95% natural gas fuel is successfully completed on March 30, 2023, at the 485-MW Long Ridge Energy Terminal combined cycle power plant—a flagship GE HA-class project that is purpose-built to transition from natural gas to hydrogen blends and ultimately be capable of burning 100% hydrogen. The Guangdong Huizhou combined cycle power plant, powered by two 9HA.01 gas turbines, is notably expected to be the first to burn hydrogen blended with natural gas in mainland China.
At this point, GE suggests its H-class gas turbine portfolio has the capability to burn up to 50% by volume of hydrogen when blended with natural gas. The capability is enabled by the DLN2.6e combustion system that is standard on current 9HA.01/9HA.02/7HA.03 gas turbine offerings. The company has also unveiled a technology roadmap to achieve 100 percent hydrogen burn capability in this platform by 2030.
2022 GE’s Exploration of Carbon Capture from Gas Power Gains Steam
In February 2022, GE Gas Power wins a $5.8 million award from the DOE to develop a detailed plan for integrating carbon capture technologies with natural gas combined cycle plants, and potentially deploy a commercial project by 2030. The project’s front-end engineering design (FEED) will be focused on Southern Co.’s James Barry Plant in Alabama, which is powered by two GE 7F.04 gas turbines. It explores the integration of Linde’s Gen 2 carbon capture solution based on BASF OASE blue technology. GE notes that the FEED could represent a “pre-requisite for future construction projects, and it can accelerate commercial deployment of other projects.”
The project comes on the heels of a contract award by BP as a part of a consortium to develop a FEED for a large amine-based post-combustion “at scale” solution to integrate with an H-class gas power plant at the Net Zero Teesside (NZT) Power project and the Northern Endurance Partnership’s (NEP) carbon compression infrastructure in Teesside, UK. GE has also since signed MOUs with QatarEnergy to explore the feasibility of developing a carbon hub at Ras Laffan Industrial City, where more than 80 GE gas turbines operate, and with Norway’s Northern Lights. In October 2022, it signed an MOU with South Korean EPC company DL E&C Co. to jointly explore a roadmap for carbon capture technology integration with GE combined cycle plants in Asia and Oceania.
In 2023, notably, GE Vernova made an equity investment as part of an agreement with technology firm Svante to develop and evaluate solid sorbent-based carbon capture technology for natural gas power generation applications.
2022 First 7HA.03 Turbines Begin Operation at Dania Beach
GE in June 2022 begins operation of the first two GE 7HA.03 machines—currently the largest 60-Hz heavy-duty gas turbines in the world and the most efficient in GE’s fleet—at Florida Power & Light’s (FPL’s) newly inaugurated 1,260-MW Dania Beach Clean Energy Center (DBEC) in Broward County. The two 7HA.03 gas turbines, which make up DBEC Unit 7, are slated to help FPL achieve a 70% emissions reduction compared to the previous site and boost reliability and affordability for its customer base in highly populated areas of Miami-Dade and Broward counties.
FPL—a regulated entity—agreed to be GE’s first customer for the 7HA.03 in 2019, given the rapid rate of significant changes it projected over the next decade. The rapid transition is posing similar dilemmas for utilities all over the world, including as they relate to forecasted natural gas costs; projected costs for new generating units; the efficiency with which generating units convert fuel into power; and costs related to environmental impacts.
2022 GE Unveils New Name for Power Segment: GE Vernova
In July 2022, GE announces its planned energy portfolio spin-off will be called “GE Vernova” with Scott Strazik, who previously led GE Gas Power and later, GE Power, as its new CEO. The name GE Vernova “is a combination of ‘ver,’ derived from ‘verde’ and ‘verdant’ to signal the greens and blues of the Earth, and ‘nova,’ from the Latin ‘novus,’ or ‘new,’ reflecting a new and innovative era of lower carbon energy that GE Vernova will help deliver,” the company says. The spin-off is scheduled at the beginning of the second quarter of 2024, when GE Vernova will be listed on the New York Stock Exchange as “GEV.”
2023 Collaboration on Ammonia Combustion Technology
GE Vernova’s Gas Power business announces a memorandum of understanding with IHI Corp. (IHI), a leading heavy industry manufacturer based in Japan, to jointly develop ammonia combustion technologies for heavy-duty gas turbines to generate electricity with reduced or near zero CO₂ emissions. In October 2023, this is followed with a three-way MOU signed by Sembcorp Industries, IHI, and GE Vernova’s Gas Power business to jointly explore the potential retrofitting of Sembcorp’s Sakra gas-turbine power plant in Singapore with ammonia-firing capabilities.
2023 GE Vernova’s HA Gas Turbine Fleet Achieves 2 Million Operating Hours
Ge Vernova’s Gas Power business in September 2023 announces its H-Class heavy-duty gas turbine fleet has accumulated more than two million commercial operating hours across 88 units globally. “Since the first commercial operation of the company’s flagship HA gas turbine in 2016, the HA fleet now boasts an installed capacity of 47 GW of power, the equivalent capacity needed to power 35 million American homes,” the company says.
2024 GE Vernova Marks Completion of Spin-off From GE
Marking the completion of its spin-off from GE, GE Vernova begins trading on the New York Stock Exchange on April 2, 2024, as an independent company “singularly focused” on accelerating the energy transition. The measure, approved by GE’s Board on Feb. 29, effectively establishes GE Vernova as a giant purpose-built firm that will leverage its technology and solutions to empower electrification and decarbonization. The company embarks on its corporate path housed at its new headquarters in Cambridge, Massachusetts. The new firm is comprised of three key segments: Power (composed of its Gas, Steam, Hydro, and Nuclear divisions); Wind (which includes Onshore Wind, Offshore Wind, and LM Wind Power); and Electrification (comprising Grid Solutions, Power Conversion, Solar & Storage Solutions, and Electrification Software).
2024 Launch of 100% Hydrogen-Fueled Aeroderivative Gas Turbine Solution
GE Vernova unveils a 100% hydrogen-ready aeroderivative gas turbine solution based on its LM6000VELOX package. The first-of-a-kind technology is set to be showcased at the 200-MW Whyalla hydrogen power plant in South Australia, with commissioning slated for early 2026. “It is projected to mark the first time a GE Vernova power plant project, at a commercial scale, is powered by aeroderivative gas turbine combustion technology capable of operating on 100% hydrogen,” the company noted.
—Sonal Patel is a POWER senior editor (@sonalcpatel, @POWERmagazine).
Editor’s note: This article will be updated to reflect new milestones. Last update: Nov. 20, 2024
- E-class
- GE
- GT13E
- GT26
- B-class
- Alstom
- GT24
- H-class
- Belle Isle Station
- France
- GT26 HE
- renewables
- Neuchâtel
- Malaysia
- turbine inlet temperature
- steam turbines
- PURPA
- DLN
- history
- TIT
- Blackout
- BBC
- EDF
- H-class system
- aeroderivatives
- HRSGs
- Baglan Bay
- F-Class
- distributed generation
- LM
- gas turbines
- market competition
- UK
- Frame machines
- NOx
- G-class
- GE Gas Power
- ABB
- J-class
- condensers
