Home Legal & Regulatory NRC Proposes Deep Fee Cuts for Advanced Nuclear
The Nuclear Regulatory Commission (NRC) has proposed to sharply reduce its hourly service fees—by more than 50%—for advanced nuclear reactor applicants and pre-applicants in a move designed to incentivize innovation and accelerate the deployment of next-generation nuclear technologies.
In a proposed rule published in the Federal Register on Feb. 19, the regulatory body moved to revise its fees for licensing services, inspection services, and special projects (under 10 CFR part 170) by establishing a two-tiered hourly rate system.
Starting in August 2025, the agency plans to raise the professional hourly rate from $317 to $323. This increase, the NRC said, is driven by “an approximately $5.4 million increase in resources requested in the FY 2025 budget request.” The agency earmarked these funds to support several key initiatives, including:
  • Technical reviews of 10 CFR Part 50 construction permit applications, including to facilitate reviews necessary for construction permit applications for non-power reactors.
  • The relocation, design, and construction of the Headquarters Operations Center (HOC) to enable the NRC to exit one of its headquarters buildings before its lease expires in November 2027.
  • Development and implementation of IT and cybersecurity upgrades, including an artificial intelligence (AI) infrastructure to facilitate responsible AI adoption. (The measure is in line with Executive Order 14110, which the Trump administration revoked on Jan. 20).
  • Increased salaries and benefits to support federal pay raises for NRC employees, an effort that seeks to ensure the agency can retain and attract qualified personnel.
A Drastically Reduced Rate of $146/Hour
However, in a bid to implement Section 201 of the ADVANCE Act, which revised the 2019 Nuclear Energy Innovation and Modernization Act’s (NEIMA’s) fee structure, the NRC proposed a drastically Reduced Hourly Rate of $146 for advanced nuclear reactor applicants and pre-applicants. The lower rate is slated to take effect on Oct. 1, 2025 (when the ADVANCE Act provisions become effective)—which would fall into the NRC’s FY2026 budget. The ADVANCE Act, notably, sunsets the Reduced Hourly Rate for advanced nuclear reactor pre-applicants on Sept. 30, 2030.
Signed into law on July 9, 2024, the legislation mandates that costs associated with international nuclear export and innovation activities (Section 101) be excluded from the fees collected by the NRC. It also exempts costs related to reviews and pre-application work for early site permits required to demonstrate advanced nuclear reactors at the Department of Energy (DOE) or critical national security infrastructure sites (Section 204) from NRC’s fee calculations. The NRC’s proposed rule indicates these provisions may take effect as part of its FY2026 rule.
The NRC’s decision to front-load the Section 201 change in the FY25 rule, rather than waiting for the FY26 rule, is a strategic move that will avoid billing delays and provide early notice and initiate an opportunity to comment, it said. Pivotally, “It also would provide greater regulatory certainty to external stakeholders for planning and budgeting for future 10 CFR part 170 service fees for advanced nuclear reactor applicants and pre-applicants,” it said.
The proposal also specifically defines which entities could qualify for reduced fees. It defines an “advanced nuclear reactor applicant” as an entity that has formally applied for a license to build and operate an advanced nuclear reactor. That application must be for an initial operating, combined, or manufacturing license—not for an amendment to or renewal of an existing license. An “advanced nuclear reactor pre-applicant” is an entity that has submitted a detailed licensing project plan outlining its intention to apply for a future license for an advanced nuclear reactor. Again, that future license must be for an initial operating, combined, or manufacturing license. The NRC has proposed to limit these applications to advanced nuclear reactors as defined in NEIMA.
According to the proposal, the reduced hourly rate will also only apply to certain activities related to the review of applications submitted by advanced nuclear reactor applicants and pre-applicants. Specifically, fees assessed for reviewing an advanced nuclear reactor applicant’s formal licensing application could qualify, as may fees related to reviewing submitted materials that are explicitly outlined in a licensing project plan from a pre-applicant. Other NRC activities, such as license amendments or renewals, will continue to be billed at the full professional hourly rate of $323.
In recent years, the agency has also revised how it calculates fees for small modular reactors (SMRs) as part of broader efforts to tailor costs to emerging nuclear technologies. In 2016, the NRC modified its rules (10 CFR 171.15) to establish a specialized method for calculating annual fees for small modular reactors (SMRs) that use light-water reactor (LWR) technology. In 2023, the NRC expanded those provisions to include all SMRs (not just LWRs) and introduced a reduced minimum fee and adjusted fee structure for very small SMRs (250 MWth or less). The agency’s proposed rule says fee calculations for bundled SMR units and larger SMRs (over 250 MWt) will remain unchanged, and because no SMRs are currently in operation, the NRC will not impose specialized SMR fees in 2025.
Regulatory Relief for Advanced Reactors
The NRC’s proposal is poised to be well-received by the advanced nuclear industry, which has consistently called for measures to reduce regulatory costs and streamline licensing pathways. In a 2021 report, the Nuclear Innovation Alliance (NIA) suggested hourly fees have rapidly risen from an average of $214/hour between 1995 and 2004 to $280/hour over the last several years. The report argues that the NRC’s current fee structure has posed a significant barrier to the development and deployment of advanced nuclear reactors, disproportionately burdening new entrants and hindering innovation.
“The open-ended costs associated with paying fees impose barriers to new entrants,” the report explains. “License applicants must pay NRC fees before they begin earning revenues. This is particularly burdensome for developers with limited capital and new customer types like small towns, rural communities, and industrial users. NRC is in the process of modernizing its existing regulatory framework, which was designed for light water reactors. At least until this modernization is complete, advanced reactor licensing requires significant extra regulatory work,” it says.
The NRC on Thursday said its FY25 budget request is $994.9 million. It proposes to use $20 million in carryover funds, making the total budget authority used in the FY25 proposed fee rule $974.9 million—an increase of $30.8 million from FY24. Under NEIMA, the NRC is required to recover approximately 100% of its total budget authority in FY25, except funds for specific excluded activities. After accounting for the excluded activities and net billing adjustments, the NRC estimates that it must recover approximately $826.1 million in fees in FY25. Of that amount, the NRC estimates that $216 million will be recovered through service fees under 10 CFR Part 170, and $610.1 million will be recovered through annual fees under 10 CFR Part 171.
Compared to FY24, the agency’s proposed annual fees would increase for licensed operating power reactors, spent fuel storage/reactor decommissioning activities, non-power production or utilization facilities, transportation activities for the DOE, the Uranium Mill Tailings Radiation Control Act Program, and 48 materials users fee categories. The proposed annual fee for each operating power reactor in FY2025 is $5,359,000, up from $5,336,000 in FY 2024. In addition, each reactor will be assessed a spent fuel storage/reactor decommissioning fee of $341,000, up from $326,000 in FY2024. That represents a total annual fee per reactor to $5,700,000—an increase from $5,662,000 in FY 2024. The proposed annual fees would remain stable for fuel facilities, it said.
The NRC is actively seeking feedback on all aspects of the proposed rule. The deadline for submitting comments is March 21, 2025. The agency is expected to hold a public meeting to describe the FY2025 proposed rule and answer questions from the public. The NRC will review all comments received and consider them in developing the final fee rule, which is expected to be published later this year.
