Home Coal Summer Power Burn: Are Generators Headed Back to Coal?
The US natural gas supply demand picture has changed with the 25% run-up in NYMEX natural gas futures prices to over $4/MMBtu this year. Prices rose because high winter demand helped demolish a huge gas storage surplus that hung over the market and depressed prices since last spring. The market should not forget however that for a time last year—with prices below $2/MMBtu and Lower 48 dry gas production through the roof—there was talk of hitting the “storage wall.” A sharp increase in power burn soaked up 6 Bcf/d of natural gas last summer and helped the market out of that scrape.
Despite all the market optimism about $4/MMBtu prices, the big question mark this year has to be where incremental natural gas demand will come from once temperatures warm up? The reason we need to answer that question is because US Lower 48 dry natural gas production is still booming along at close to record levels around 64 Bcf/d. Even if production does not increase much this year—that is still a lot of gas. Heating demand did a good job of soaking up surplus gas this winter but it won’t help once winter is over. It is worth comparing for a minute where we are today with the situation a year ago, coming out of the “non winter” of 2011-2012.
Last year (April 2012) gas storage finished winter at record levels, and commentators were talking seriously about hitting the “storage wall.” The storage wall occurs in theory when natural gas storage gets filled to the brim. (We say in theory because nobody knows when it will happen—because it never has.) The threat of the storage wall helped cause natural gas prices to collapse below $2/MMBtu. As it turned out the storage wall was headed off at the pass by an unprecedented increase in power burn—the use of natural gas for electric power generation. US total power burn between April 1 and July 31was about 720 Bcf higher in 2012 than over the same period in 2011—an increase of close to 6 Bcf/d in demand. Most analysts attributed the increased power burn to generators switching between coal and gas for power generation because gas was considerably cheaper.
So far in 2013, the power burn numbers do not look nearly so strong. The Bentek Cell Model data in March showed about 10% less natural gas consumption for power burn in 1Q 2013 than last year. If the same economics of coal-to-gas switching apply this year as last then it follows that doubling the price of natural gas from $2/MMBtu to $4/MMBtu would discourage generators from using natural gas instead of coal. That is just one school of thought, however, and many analysts disagree with this “black and white” approach to natural gas power burn and say that high levels of gas power burn are “here to stay”—even at $4/MMBtu.
To try and improve our understanding of this complex topic, we’ll revisit the analysis we did last year on the economics of power switching between coal and natural gas. Back then we looked at the comparative costs of generation to understand when power system operators might use gas fired plants instead of coal and vice versa. The theory behind our analysis is called “economic dispatch” and it dictates that once certain priorities have been attended to, such as system safety and reliability, the order of generation plant dispatch is governed primarily by fuel cost. Coal-to-gas fuel switching requires power system operators to use natural gas instead of coal when they have a choice of units to meet power load. That fuel switching increases natural gas power burn.
To calculate fuel costs we looked at generation plant economics in terms of efficiency. By this we mean how efficiently the plant converts hydrocarbons in the shape of coal or natural gas molecules into electricity. In a perfect plant, it would take 3412 Btu to generate 1 kWh of electricity at 100% efficiency. According to EIA data, an average natural gas combined cycle gas turbine (CCGT) plant runs at 44.78% efficiency, and an average coal plant has 33.64% efficiency. These efficiency rates are also known as heat rates. We translated these efficiency numbers into $/MWh by applying an efficiency factor to NYMEX natural gas and NYMEX Appalachian coal prices. To save time here, we will cut to the chase and tell you that to get our results we multiplied the gas price ($/MMBtu) by 7.619 and the coal price ($/ton) by 0.4226. The chart below shows the fuel cost comparison data since the start of 2012.
1. The convergence of gas and coal prices that spurred coal-to-gas switching in 2012 has come to an end this spring. Courtesy: RBN Energy
The fuel cost for our typical natural gas plant is the blue line on the chart and the fuel cost for a typical coal plant is the red line. You can see that the gas cost is below the coal cost until the end of Sept. 2012 (green circle). That was the time period when most coal-to-gas fuel switching happened last year. After September, coal costs stayed close to or below those for natural gas generation, and coal-to-gas fuel switching declined. Since the end of Feb. 2013, the cost of natural gas has increased by over $5/MWh while coal has fallen slightly (black circle). In other words, the recent upturn in natural gas prices has made it about 16% more expensive to generate electricity with natural gas than with coal using our typical plant configuration. In fact, the cost of power generation with coal has been less expensive for most of this winter. The chart below looks at the same data in a slightly different way to make the point more clearly.
2. Looked at another way, gas-fired power has on average been more expensive than coal-fired power on a MWh basis since last fall. Courtesy: RBN Energy
This time we plotted the difference or spread between the coal and gas generation costs (blue shaded area). The zero line is marked in black in the middle of the chart. Gas generation costs are lower when the blue shaded area is below the zero line and coal generation costs are lower when the blue shaded area is above the zero line. And that is the case right now—with higher natural gas prices—implying that right now—under economic dispatch, power system operators will run coal fired plants before they run natural gas plants.
We should mention a few caveats here. The debate about coal-to-gas switching and whether it will continue in 2013 is hard to follow clearly without recognizing a number of variables that impact the fuels used for generation:
  • New-generation CCGT plants perform better than our “typical” 45% efficiency model. A newer plant may have an efficiency level of 55% or higher. If we run that efficiency level through our generating cost calculation it means the gas cost is lower on average over the period since Jan. 2012 by about $4/MWh. That means the zero line in Figure 2 would move up by $4/MWh, and that considerably improves the likelihood that a generator would switch to gas over coal. That means that new natural gas-fired generation is far more likely to be used in place of coal than older gas fired generation that is less efficient.
  • The price for Appalachian coal that we use in our model is typically higher than the price of coal from the Midwest or the Wyoming Powder River Basin. Even though these alternatives to Appalachian coal contain less energy per ton, their price is low enough to compete with natural gas at a lower price point (so the zero line on our chart would move down—meaning more coal power burn).
  • The cost of coal used to generate electricity can often be less than other related costs such as transportation to the generation plant. This is actually often the case for coal from the Powder River Basin in Wyoming. Coal transportation (usually by rail) is relatively expensive and can impact coal generation economics significantly.
  • Generally speaking, in the battle for generating capacity, natural gas is gaining over coal not just based on the relative cost of generation but because coal fired plants are being retired and natural gas generation plants are being built to replace them. In our recent examination of the costs of coal generation plant emissions, we noted that 10% of the US coal fired fleet is expected to retire between 2012 and 2016 (30 GW of power). In another recent posting we looked at the impact of carbon legislation in California on coal generation in that state and observed that the legislation would increase natural gas power burn. That means natural gas power burn is increasing regardless of comparative generation costs.
  • Power burn using natural gas is constrained in many regions of the US because the infrastructure to ensure gas deliveries to power generators is not adequate. One result of this is that natural gas power burn in the winter is likely to be lower in regions where residential and commercial heating demand is high because gas pipelines cannot serve both needs at once. This factor may induce increased power burn in the Northeast and Midwest U.S. as temperatures warm up.
In Our Humble Opinion
Taking all these variables into account, the issue of whether or not power burn is going to soak up surplus natural gas supplies this summer is certainly not cut and dried. We believe the fundamentals will drive the behavior of power generators so that unless natural gas prices decline relative to coal, the power burn this summer will be lower than last because generators will use more coal. Over time it is clear that natural gas is winning the battle against coal in terms of plant retirement and new builds—but we can’t imagine why coal companies would stand by and give up their existing markets to the extent that they have a cost advantage. The implication of this market view is that power burn levels will be lower this year than last. That will increase the surplus of gas production over demand and increase the amount of gas going into storage. Increased storage levels will likely put downward pressure on prices—perhaps enough downward pressure to stimulate higher power burn levels. The moral to this story—economics 101 works.
—Sandy Fielden is director of energy analytics for RBN Energy. This article was originally published on the RBN Energy Blog and is republished with minor edits for this publication.
