In-Line Vibration Transmitter
IMI Sensors released model 682A09 ICP In-Line 4-20 mA Vibration Transmitter, a device that installs with any industrial accelerometer and converts the vibration signal to a 4-20 mA velocity output that can be trended with today’s PLC, DCS, or SCADA control room systems. Its sleek design installs right into the cable run. No DIN rails, cabinets, or special power are required. The 682A09 is a stainless steel, hermetically sealed design capable of operating in the harshest environments with 2-pin MIL connector input and 3-pin MIL connector output. It accepts a 100 mV/g analog signal and operates off of loop-power supplied by the PLC, DCS or SCADA system. The analog signal can be run to a central collection point, allowing the user to maintain the FFT capability of the original system. (http://www.imi-sensors.com)
