Home O&M Three Genset PM Tips to Keep Mission-Critical Standby Power Available
Aaron Sage
Essential infrastructures, like hospitals or data centers, can’t afford to let severe weather, peak demand, or voltage fluctuations disrupt normal operations for even a moment. Unfortunately, increasing electricity demand and aging grids are making interruptions more likely—spurring facilities to invest in gensets to secure nonstop access to mission-critical standby power.
The biggest challenge is ensuring genset units are ready for action, even if they haven’t been used recently. When power runs smoothly, they’re out of sight and out of mind. Other challenges include hard-to-reach locations, fill and drain ports that don’t work well with the old-school buckets and funnels method, and a misconception that low runtime means low maintenance needs. Take those together, and it’s clear why preventive maintenance (PM) work gets deprioritized when more pressing issues pop up.
Facility management teams aren’t alone in that. After 25 years in the preventive maintenance industry, I’ve seen more than my fair share of equipment crews who have fallen behind on PM schedules. Luckily, I’ve also seen the difference a streamlined PM plan can make. But before I share my tips, let’s dive into the cost of neglected maintenance.
What Happens When Maintenance Falls to the Wayside
Infrequent or nonexistent genset maintenance can have serious repercussions. Fluids degrade, additives settle, and moisture can build up even when a standby unit rarely runs. If the genset is frequently used, a lack of regular maintenance will put additional stress on the equipment.
In either scenario, a long run time or heavy load can push the equipment over the edge and leave facilities without power when it’s needed most. That could mean significant financial losses, not to mention the impact on people who depend on hospitals, data centers, and other critical infrastructure.
How to Streamline Genset Maintenance
For facilities with just a few gensets on-site, preventive maintenance might feel like one more thing on the to-do list. For data centers with hundreds to maintain, the task is a more significant hurdle. However, three relatively simple strategies can help management teams across the spectrum streamline service. I’ve seen these work time and again for crews across industries.
  1. Build Preventive Maintenance Practices at the Fleet Level, Not by Unit. Some crews prioritize units that run more frequently than others, but every genset needs service. A fleet-level schedule that rotates through every unit at regular intervals is better for the equipment and the team. The consistency means each unit is regularly inspected, allowing technicians to intervene before any minor issues become serious problems. Meanwhile, a fleet-level approach to maintenance allows the team to focus more on the larger process and less on the condition of individual units.
  2. Plan Maintenance Around the Hardest-to-Reach Units. Many facilities are designed with genset units purposely placed out of the way because of noise, exhaust, and fuel-safety requirements. That supports day-to-day workflow but can complicate preventive maintenance. Crews need to map out the service schedule around the most challenging areas, ensuring they have everything needed to tackle the job before it starts.
  3. Invest in Equipment Engineered for Easier Maintenance. Genset maintenance is a unique challenge. It deserves a unique solution. Sage Oil Vac pump-free mobile lube systems offer a closed system that protects a facility from spills while speeding up the fluid change process. Our exclusive technology uses compressed air to build vacuum pressure that moves fluids to and from tanks. The process happens cleanly, thanks to hoses that directly connect a lube truck, van, or trailer to genset drain and fill ports. It’s a definite upgrade from funnels and buckets that don’t work well with genset fluid ports.
It’s Time to Prioritize Mission-Critical Maintenance
Service teams play an essential—but often unseen—part in critical infrastructure. Regular genset maintenance ensures the focus can stay on the work instead of scrambling to restore power when it’s needed most.
—Aaron Sage is the CEO of Sage Mfg., the parent brand behind Sage Oil Vac, Amarillo Tanks, and Amarillo Upfitters.
