Home O&M Power Plant Valves and Operators: Critical Components That Have to Work When Needed
Valves and the actuators that move them are routine, well-maintained plant equipment. What is changing is how much they can report about their own condition, and how closely owners weigh their energy use and service life. Manufacturers are rethinking how these devices are built, monitored, and qualified as plants cycle harder, take on hydrogen-capable duties, and run beyond their original design lives.
Material from two equipment makers describes three developments: digital diagnostics that shift maintenance from reactive to planned, a closer look at lifetime energy and service costs, and, in nuclear plants, strict qualification and obsolescence demands that make replacement far more than a mechanical swap.
Data at the Valve
According to AUMA, its PROFOX line of electric actuators comes in multi-turn, part-turn, and linear versions for the lower torque and thrust ranges. The company says variable-speed direct-current motors allow fast, precise positioning suited to closed-loop control, with speed profiles that can be tuned to a process.
The more significant change may be what the actuator records. AUMA says the devices log motor starts, run time, temperatures, and warning events, and that analysis of those logs can reveal maintenance needs and process adjustments before an unplanned outage occurs.
Technicians can configure the actuators with a smartphone app or AUMA’s RSTX 100 handheld remote (Figure 1). The company says the remote works over Bluetooth at up to 20 meters, so staff can operate an actuator in a pit or at height without climbing or entering a confined space. AUMA says the unit is certified intrinsically safe, and can set end positions, update firmware, and pull log data for analysis in its CORALINK platform. For hydrogen service, AUMA offers an explosion-proof version, PROFOX X, certified for gas group IIC, which includes hydrogen.
1. AUMA’s RSTX 100 handheld remote can operate its actuators from up to 20 meters away. Courtesy: AUMA
Counting the Cost of Standby
AUMA also makes an operating-cost argument for electric actuation over pneumatic. Pneumatic actuators depend on a constant supply of compressed air, the company notes, while electric units draw significant power mainly while moving. With dozens or hundreds of actuators on a site, AUMA says, the difference adds up.
Remote assets sharpen the point. AUMA says a high-voltage direct-current converter platform at an offshore wind farm typically uses up to 800 of its actuators, mostly in the cooling system, where the cost of reaching equipment for maintenance is high.
Nuclear: Right Force, Right Time
In nuclear plants, Rotork says actuators must deliver the force and speed required under emergency conditions without damaging valve stems, seats, or gear trains during normal operation. Sizing needs enough margin to overcome the highest expected valve loads, but too much output stresses mechanical components. Rotork says torque-limiting arrangements that work independently of the actuator’s normal torque switches, and thrust compensation that absorbs stem expansion from temperature changes, help strike that balance.
Safety-related actuators must also be qualified for the conditions where they will operate. Rotork says testing can include radiation and thermal aging, mechanical cycling, pressurization, vibration, and seismic loading, with the goal of showing the actuator can complete its safety function, not merely survive.
As reactors operate beyond their original design lives, Rotork argues, replacing an actuator means revisiting valve loads, operating times, power conditions, interfaces, and qualification criteria. Gearboxes may be needed to raise torque or convert output for quarter-turn valves, so the actuator, gearbox, and valve should be treated as one engineered system.
Whether the plant is a reactor or an offshore converter platform, the requirement is the same: a valve must move when called upon.
—POWER
ExperiencePOWERlogo
Washington, D.C.
Register Now
