Small-Diameter Split Frame
E.H. Wach’s newly launched Small Diameter Split Frame (SDSF) is an externally mounted machine tool for cutting, beveling, and counterboring pipe from 0.84 inch to 4.5 inch diameter. Featuring a self-squaring clamping system for precise cutting results that are typically available only with fixed machine tools, the SDSF is also capable of performing socket weld removal and chipless wheel cutting. The SDSF is optimized for low-clearance environments and offers simple setup and operation. (www.ehwachs.com)
