Innovative Fire Extinguisher Mount
Poly Performance’s newly launched Quick Release Fire Extinguisher Mount offers an innovative way to safely mount a fire extinguisher to any flat or round surface. The mount can be secured with either bolts or hose clamps. Configurable for any size fire extinguisher, the mount offers split-second removal to maximize emergency preparedness. Poly Performance manufactures the two-piece mounting system from laser-cut 3/16-inch and 1/8-inch-thick high-strength steel. Zinc plating provides corrosion resistance—even in marine environments—and a finished look. (http://www.polyperformance.com)
