Home Commentary Switching from Coal to Natural Gas Does Little for Global Climate
Our recent National Center for Atmospheric Research study underscores the complex and sometimes conflicting ways in which fossil fuel burning affects Earth’s climate. While coal use causes warming through emission of carbon dioxide, it also releases comparatively large amounts of sulfates and other particles that, although detrimental to the environment, cool the planet by blocking incoming sunlight.
The situation is further complicated by uncertainty over the amount of methane that leaks from natural gas operations. Methane is an especially potent greenhouse gas.
Our computer simulations indicate that a worldwide, partial shift from coal to natural gas would slightly accelerate climate change through at least 2050, even if no methane leaked from natural gas operations, and through as late as 2140 if there were substantial leaks (see figure). After that, the greater reliance on natural gas would begin to slow down the increase in global average temperature, but only by a few tenths of a degree.
1. Shifting from coal to natural gas would have limited impacts on climate, new research indicates. If methane leaks from natural gas operations could be kept to 2.5% or less, the increase in global temperatures would be reduced by about 0.1 degree Celsius by 2100. The reduction in global temperatures would be more minor with higher methane leakage rates. Courtesy: Springer, modified by UCAR
Relying more on natural gas would reduce emissions of carbon dioxide, but it would do little to help solve the climate problem. It would be many decades before it would slow down global warming at all, and even then it would just be making a difference around the edges.
A Small Impact on Temperatures
The burning of coal releases more carbon dioxide than other fossil fuels, as well as comparatively high levels of other pollutants, including sulfur dioxide, nitrogen oxides, and particles such as ash. Since natural gas emits lower levels of these pollutants, some energy experts have proposed greater reliance on that fuel source as a way to slow down global warming and reduce the impacts of energy use on the environment.
But the effects of natural gas on climate change have been difficult to calculate. Recent studies have come to conflicting conclusions about whether a shift to natural gas would significantly slow the rate of climate change, in part because of uncertainty about the extent of methane leaks.
Our new study attempts to take a more comprehensive look at the issue by incorporating the cooling effects of sulfur particles associated with coal burning and by analyzing the complex climatic influences of methane, which affects other atmospheric gases such as ozone and water vapor.
By running a series of computer simulations, we found that a 50% reduction in coal and a corresponding increase in natural gas use would lead to a slight increase in worldwide warming for the next 40 years of about 0.1F (less than 0.1C). The reliance on natural gas could then gradually reduce the rate of global warming, but temperatures would drop by only a small amount compared to the 5.4F of warming projected by 2100 under current energy trends.
If the rate of methane leaks from natural gas could be held to around 2%, for example, our study indicates that warming would be reduced by less than 0.2F by 2100. The reduction in warming would be more pronounced in a hypothetical scenario of zero leaks, which would result in a reduction of warming by 2100 of about 0.2-0.3F. But in a high-leakage rate scenario of 10%, global warming would not be reduced until 2140.
Whatever the methane leakage rate, you can’t get away from the additional warming that will occur initially because, by not burning coal, you’re not having the cooling effect of sulfates and other particles. This particle effect is a double-edged sword because reducing these particles is a good thing in terms of lessening air pollution and acid rain. But the paradox is that when we clean up these particles, it slows down efforts to reduce global warming.
In each of the leakage scenarios, the relative cooling impact of natural gas would continue beyond 2100, continuing to offset global warming by several tenths of a degree.
The study also found that methane leaks would need to be held to 2% or less in order for natural gas to have less of a climatic impact than coal due to the life cycle of methane. Both coal mining operations and the use of natural gas release varying amounts of methane, but the escaping gas’s influence on climate also depends on emissions of other gases, such as carbon monoxide and nitrous oxides, which affect the amount of time methane remains in the atmosphere.
A Range of Possible Methane Leaks
To compare the impacts of natural gas and coal, there are a number of studies that have evaluated emissions of sulfur dioxide and other pollutants from coal, as well as methane associated with the use of both fuels. Rather than try to assign a fixed percentage to methane leaks from natural gas operations, which can vary widely and are difficult to measure, we instead analyzed the impacts of leakage rates from 0 to 10%—a broad range that encompasses existing estimates.
To project future energy demand, we used a midrange estimate by the U.S. Climate Change Science Program that assumed no changes in government energy policies. We also assumed that sulfur dioxide emissions from coal would drop sharply over the next few decades due to pollution control devices.
We then analyzed the impacts of a 50% reduction in coal burning by using a simplified computer climate model known as MAGICC (Model for the Assessment of Greenhouse-gas Induced Climate Change). The software simulates changes in atmospheric levels of greenhouse gases and their influences on global climate.
—Contributed by Tom Wigley, a senior research associate for the National Center for Atmospheric Research. The University Center for Atmospheric Research (UCAR) manages the National Center for Atmospheric Research under sponsorship by the National Science Foundation. Any opinions, findings and conclusions, or recommendations expressed in this piece are those of the author(s) and do not necessarily reflect the views of the National Science Foundation. The study was published as "Coal to Gas: The Influence of Methane Leakage" in the October issue of Springer’s Climate Change Letters (paid access required). This content first appeared on the UCAR website; it has been edited for this publication.
