Power infrastructure has to expand faster, but the projects themselves are not getting simpler. Engineering and skilled production resources remain constrained while utilities and energy companies continue to add substations, renewable generation and storage, and distributed infrastructure. At the same time, every project brings unique site conditions, equipment, standards, and operating needs.
That creates a difficult question: How do you accelerate deployment without turning every new project into another one-off engineering exercise?
The answer lies in standardizing the parts of the process that should not have to be reinvented.
Standardize What Repeats
Standardization is sometimes mistaken for forcing every project into the same design. In practice, effective standardization should do the opposite. It identifies reoccurring elements—such as approved components, typical circuit structures, documentation formats, enclosure architectures, power-distribution concepts, naming conventions, and engineering rules—and creates a reusable foundation for them.
Engineers can then spend more time on the conditions that make a project unique instead of rebuilding common functions from scratch.
As project volume increases, that solution offers higher value; it becomes easier to adapt proven designs for additional substations, renewable-energy installations, storage systems, or auxiliary power applications while still accommodating different ratings, layouts, loads, and site requirements.
Make the Engineering Data Reusable
A standardized schematic is valuable, but the larger opportunity is the data behind it. If component information, bills of materials, physical layouts, etc. have to be recreated or manually interpreted at each downstream step, much of the benefit of standardization disappears.
The more strategic approach is to treat engineering information as data that can flow throughout the project lifecycle.
Structured component data can support electrical design, which can then contribute to procurement and documentation. A 3D digital model can add physical placement, routing, clearances, and manufacturing information, while production can then work from data already established during engineering. This consistent data use across planning, procurement, manufacturing, and operations is a key element in scaling power-infrastructure projects.
The result is less repeated interpretation between the people who design the system and the people who have to build, install, service, and expand it.
Standardize the Physical Platform, Too
Digital standards can only go so far if every physical system is still being engineered from the ground up. The same modular thinking should extend into enclosures, power distribution, climate control, and other infrastructure. A standardized physical platform gives engineering teams known dimensions and configuration rules that can be reused while individual projects remain flexible.
For power distribution in particular, modularity can make future changes easier. Capacity, feeders, protective devices, or system configurations may change over the life of an installation, but designing around scalable, standardized architectures can reduce the amount of redesign required.
That is especially important when infrastructure may need to support new generation sources, storage, changing loads, and/or future expansion. Thus, modular, standardized systems help to simplify the planning, construction, and later expansion processes.
Think Beyond the First Project
The largest benefit of standardization often appears after the first installation; once a proven architecture exists, the engineering knowledge behind it can become the starting point for the next site.
Consistent documentation can also make systems easier to understand during commissioning, maintenance, and future upgrades. When several facilities or project partners work from the same underlying standards, successful engineering decisions become easier to reproduce across the organization. This can become an indispensable source of capacity.
Bringing Digital Engineering and Modular Hardware Together
This is where the combined Rittal and Eplan approach becomes especially relevant.
Eplan’s energy and power solutions provide the digital engineering foundation for standardizing project data and reusing proven designs. Eplan Electric P8 supports structured electrical engineering and documentation, while Eplan Pro Panel can extend that information into a 3D digital twin with physical layout, routing, and manufacturing data.
Rittal carries the same standardization principle into the physical infrastructure through its energy and power solutions, including standardized enclosure, climate-control, and power-distribution systems. One example is RiLineX, a modular 60 mm busbar platform designed for AC and DC power distribution. Rittal reports potential savings of up to 30% in engineering with Eplan and up to 75% in assembly.
The larger lesson then becomes, “power infrastructure can scale faster when every new project does not have to start at zero.” By connecting reusable engineering data with modular physical systems, organizations can create a more repeatable path from design through implementation, and devote scarce engineering expertise to the challenges that truly require it.
Planning your next power infrastructure project, or trying to remove complexity from one already underway? Contact Rittal and Eplan to discuss your current challenge and how a more standardized approach could help.
