Home Hydrogen Lawrence Livermore Lab, Verne Demonstrate Hydrogen Production Program
California-based Lawrence Livermore National Laboratory (LLNL) and hydrogen technology group Verne have demonstrated a novel pathway for creating high-density hydrogen through a research program funded by the federal government’s ARPA-E group. The companies announced their results on March 18.
The demonstration validated that it is possible to efficiently reach cryo-compressed hydrogen conditions with liquid hydrogen-like density directly from a source of gaseous hydrogen, substantially reducing the energy input required compared to methods that rely on energy-intensive hydrogen liquefaction.
The energy density of hydrogen on a mass basis is extremely high. However, at ambient conditions gaseous hydrogen requires a relatively large volume to compete with other forms of energy storage.
To reduce the storage volume required, densification of hydrogen is typically accomplished using compression or liquefaction. This work demonstrated a pathway that uses both compression and cooling at the same time, each to a lesser degree than when used independently.
So far, the hydrogen supply chain has been hindered by a trade-off between gaseous hydrogen—which is cheap to produce, but low in density—and liquid hydrogen, which is high in density, but expensive to densify (via liquefaction). This trade-off has led to expensive distribution costs that have limited the adoption of hydrogen solutions.
This demonstration validates that cryo-compressed hydrogen can break this trade-off by creating high-density hydrogen without requiring the significant energy inputs required of hydrogen liquefaction.
Enabling End-Use Applications of Hydrogen
Annual U.S. power consumption is projected to grow by 800 Twh by 2030, with data centers and electric vehicles driving 77% of this new demand. Customers from a variety of sectors are seeking increased electrical power and are not currently being served by the grid.
Hydrogen can be delivered to these sectors and converted to electricity on-site through a fuel cell, engine or turbine. However, the cost of existing hydrogen distribution technologies has limited adoption.
“This demonstration confirms that cryo-compressed hydrogen can break the current trade-off between density and cost,” said Ted McKlveen, co-founder and CEO of Verne. “Providing a low-cost way to reach high densities will bring down the cost of delivering and using hydrogen, opening up a host of applications for hydrogen across some of the most demanding sectors of the economy from construction to ports to warehouses.”
Collaboration Between National Lab and Industry
Cryo-compressed hydrogen was originally investigated at LLNL in the late 1990’s by Salvador Aceves, who demonstrated its benefits with his team through thermodynamic modeling and built three generations of tanks.
After its founding at Stanford University in 2020 to explore hydrogen applications in heavy industry, the Verne team began researching cryo-compressed hydrogen and signed Aceves (then retired from LLNL) as a technical adviser.
Verne began working with LLNL in 2021 through a Strategic Partnership Project to test Verne’s tanks at LLNL’s cryogenic hydrogen fueling facility. Collaborations progressed through two Cooperative Research and Development Agreements in 2023-24 facilitated by LLNL’s Innovation and Partnerships Office (IPO). This collaboration has provided Verne with access to the unique facilities and expertise required to rapidly test and develop its technology.
“Adoption of hydrogen is currently inhibited by its high cost,” said Nick Killingsworth, LLNL principal investigator and mechanical engineer. “The sum of this work demonstrates a promising path to reduce the cost and energy associated with its storage and transportation.”
In 2023, LLNL and Verne announced a record for cryo-compressed hydrogen storage, more than tripling previous records. Verne believes that the densification and hydrogen storage breakthroughs enable 40% cheaper hydrogen distribution costs relative to existing technologies; critical cost savings for enabling hydrogen usage across the economy.
LLNL Business Development Executive Jared Lynch is responsible for the laboratory’s Energy and Environment intellectual property portfolio as well as its Chemicals & Materials intellectual property portfolios. IPO is the focal point for LLNL’s engagement with industry. It aims to accelerate U.S. competitiveness by identifying new economic opportunities and solutions and transferring those to the private sector through licensing or partnerships.
More Efficient Densification Pathway Proven
The novel hydrogen densification pathway that LLNL and Verne demonstrated produces cryo-compressed hydrogen without requiring a phase change, leading to 50% energy savings relative to small-scale hydrogen liquefaction.
During the most recent demonstration, conversion of hydrogen to 81K (-314F and 350 bar (one bar is equivalent to atmospheric pressure at sea level), and densities greater than 60 grams per litter, were achieved using a catalyst-filled heat exchanger.
In addition to energy savings, this densification pathway is more modular than hydrogen liquefaction, which typically requires construction of large, centralized facilities. The increased modularity means that the hydrogen distribution network can be further optimized, locating densification and distribution hubs closer to the points of use.
POWER edited this content, which was contributed by V2 Communications.
