Home News Versatile Boiler Inspection Light
Larson Electronics announced the release of a boiler inspection light with folding boom designed to provide versatile deployment capabilities and high-output illumination. The WALBL-2X1000WMH Boiler Light features a right-angle extension arm, wheeled base, and a pair of 1,000-W metal halide lamps for effective illumination during the servicing and maintenance of boilers and tanks. The boiler light produces 220,000 lumens of light output in a wide flood pattern and features an easy-to-deploy wheeled tower with folding boom. The heavy wheeled base features four lockable steel wheels designed to allow rolling over uneven surfaces and steel floor grates, and the extendable tower arm can be adjusted vertically or angled to fit inside most boiler access doors. The telescoping arm can also be shortened or lengthened as well as angled, and an extra support leg on the boom provides added stability when the boom is fully extended. (larsonelectronics.com)
