Home News Spacer Cable Systems
Hendrix Wire & Cable, a provider of overhead and underground power distribution products, introduced its Spacer Cable Systems, a “green” solution for overhead distribution circuits. Because Spacer Cable is more compact and can withstand temporary contact with branches without causing outages, Hendrix Spacer Cable Systems can help reduce the amount of vegetation that must be removed when clearing right-of-way for distribution circuits. Reducing right-of-way clearance by 20 feet can result in up to 6.5 tons of carbon dioxide being removed from the atmosphere every year per mile, the company claims.
Unlike bare wire, which is spread over an 8-foot cross arm, a Spacer Cable circuit is confined to less than 1 foot. This reduces trimming requirements and allows multiple circuits to be placed on a single pole, or even the same side of a single pole. The result can often lead to new circuits being added to existing poles without additional vegetation removal. (http://www.hendrix-wc.com)
