Home Press Releases Maintenance-Free-Bolting concept for bolts up to M80 (3 1/8”)
ITH Bolting Technology combines digital bolting tool procedures, advanced fastener design, and installation know-how to reduce maintenance costs significantly — proven for onshore and offshore wind-turbine installation projects.
Meschede, Germany
ITH Bolting Technology is a leading global system supplier in bolting technology providing bolting tools, engineering, fasteners and service. Under their brand, IHF Fastener Systems, ITH have developed innovative fastener systems up to M80 (3 1/8”), which are specifically designed to match the technical demands of onshore and offshore wind turbine joints.
The “Maintenance-Free-Bolting” concept includes the technical coordination of ITH bolting tool systems with digital management software, specifically designed IHF fasteners, and advanced installation process know-how. The technical combination leads to repeatable, fast, and precise bolting procedures, which helps to reduce costly maintenance intervals on onshore and, especially, offshore wind turbines significantly.
Maintenance-Free-Bolting concept by ITH Bolting Technology: IHF bolts, IHF Roundnuts, and digital monitoring and application management for ITH Bolt Tensioning Cylinders.
Bolting tool method and digital management software
ITH bolt tensioning cylinders work according to the hydraulic, torsion-free, and friction-free bolt tensioning method. The method guarantees reproducible pre-tensioning forces within a close tolerance of ±2.0 percent.
For this method, ITH has developed a digital application management system, which offers customizable functions such as data-logging and step-by-step user guidance.
Depending on the demand of the customer, the bolting procedure and functions can be modified. All captured data such as applied pressure, applied preloads, angles of rotation of the nut run-down, bolt-ID, and more application data can be sent to a customer cloud.
Conventional HV-standard configuration (HV stands for “high strength”) compared to IHF fastener configuration and applied preloads for bolt size M36 (1 3/8”).
Multi-certified IHF Fastener design and benefits
Bolted joints on steel constructions can be classified according to the HV-standard (HV stands for high-strength) according to DIN EN 14399 and DASt 021. Wind-turbine tower segments are mainly subjected to this standard, which determines that bolts are torqued and fastener sets consist of a bolt, a nut, and two washers. Torqueing is subjected to friction effects, which can affect the implementation of the applied preload forces FM negatively.
IHF configuration with IHF Roundnuts: No washers required. IHF Roundnuts can be used with IHF head bolts in general up to M64, 2 1/2” or IHF studs bolts up to M80, 3 1/8”.
Innovative IHF Fasteners – head bolts (in general up to M64, 2 1/2”), studs and round nuts (up to M80, 3 1/8”) – are based on optimized design to meet the technical demands of wind turbine joints in terms of material, coatings, pre-load distribution, notch categories and dimensions.
Optimized flange design options when using IHF Fasteners.
Compared to conventional HV-standard joints, IHF Fasteners offer several advantages:
  • Integrated washers: In contrast to an HV-set, the more recent bolt and nut set consists only of two components, the IHF Stretchbolt and Roundnut, which simplifies and accelerates the installation process, especially offshore.
  • Design and optimized load distribution enable higher utilization of the material.
  • This enables a.) to use less number of IHF fasteners compared to standard fasteners or b.) reduce the dimensions of the flange.
Due to their proven design IHF Round Nuts up to M80 (3 1/8”) have received the European Technical Approval (ETA) by the DIBt (German Institute of Construction) to be applied as a substitute for conventional HV-standard fastener configurations.
Set of IHF Roundnuts and IHF head bolts.
Installation know-how and results
The “Maintenance-Free-Bolting” concept also includes several components that lead to a faster installation process. ITH hydraulic bolt tensioning cylinders can be equipped with handling systems and automatization components, which enable a semi-automatic nut run-down and an automatic nut alignment. Both automatization components are managed by the ITH software. Via an industrial touch-panel PC, users get a visual step-by-step process guidance. Bolt-tightening procedures are often subjected to the risk of possible incorrect operation, which is avoided by the user guide.
This process design not only accelerates installation procedures but also guarantees precise results. Special offshore packaging and the fact that no washers are required also simplifies and accelerates the installation.
Wind turbine application and solutions
The proven “Maintenance-Free-Bolting” concept is in use on:
  • Turbine tower bolts
  • Transition-piece to tower bolts
  • Monopile-to-transition piece
Next to the Maintenance-Free-Bolting concept, ITH Bolting Technology also provides bolting tools, fasteners and service for main wind turbine nacelle bolting applications. Comprehensive support in terms of installation supervision, tool maintenance, tool calibration and further is guaranteed by the global ITH network.
About ITH Bolting Technology
ITH Bolting Technology is the worldwide leading system supplier for tension and torque tools to tighten and loosen industrial bolt connections bigger than M16 (5/8”).
As a whole system supplier, ITH combines quality tool solutions, comprehensive engineering knowledge, innovative fasteners, and qualified services for the best technical and economic solution for business partners.
As a private-owned engineering company with a long-term business strategy, the global ITH-network includes 12 ITH-subsidiaries and more than 40 global representations.
With more than 200 international patents ITH is among the most important drivers of innovation in industrial bolting technology.
www.ITH.com
www.maintenance-free-bolting.com
