Home News Industrial Vacuum for Combustible Dusts
The new VAC-U-MAX Model 860/02 is suited for operators who want to eliminate drum handling and who need to collect and discharge powders in a safe, dust-free, and convenient way. The Model 860/02 uses the field-proven VAC-U-MAX Air-Powered Vacuum cover with manual pulse-jet filter cleaning and nonstick filtration that captures 99.9% of particles as small as 0.5 microns. The rugged portable frame includes a collection hopper with automatic discharge valve and polybag loading accessory. When the vacuum is turned off, the collected powder automatically discharges into an off-the-shelf static-conductive polybag. The Model 860/02 vacuum comes equipped with a fully grounded accessory kit, static-conductive filter media, and anti-sparking material inlet to allow the vacuum to be used in Class II, Division 2 environments, as required by OSHA. (http://www.vac-u-max.com)
