Home Blog Advancements in Solar Products and Their Role in Mitigating Carbon Emissions
The necessity for sustainable energy solutions has never been more pressing. As global carbon emissions continue to rise along with the increase of natural disasters, innovative companies are stepping up to offer practical, eco-friendly alternatives to traditional energy sources.
Advanced solar power products not only represent a technological triumph but also contribute significantly to the reduction of carbon emissions.
COMMENTARY
Solar power is one of the most abundant and renewable energy sources available. By converting sunlight into electricity, solar products provide a clean, sustainable energy solution that does not emit greenhouse gases during operation. This is in stark contrast to fossil fuels, which release a substantial amount of carbon dioxide (CO2) and other harmful emissions when burned for energy.
Solar products utilize photovoltaic (PV) technology, a method of converting sunlight directly into electricity using semiconducting materials. The basic unit of a PV system is the solar cell, which is typically made from silicon. When sunlight hits a solar cell, it excites the electrons in the silicon, creating an electric current. This current is then captured and used to power various devices or stored in batteries for later use.
Alice Chun
Photovoltaics (PV) are made using semiconductor materials that convert sunlight into electricity. Here’s an overview of the process used to create photovoltaic cells for solar panels:
Silicon Refinement: Silicon is derived from quartz sand, which is abundant on Earth. For purification, the quartz sand is processed in a furnace at high temperatures to extract pure silicon. This process removes impurities, producing metallurgical-grade silicon.
Further purification, often via the Siemens process, produces extremely pure silicon suitable for photovoltaic cells (electronic-grade silicon).
Crystal Formation: For monocrystalline silicon, single crystal silicon is made by the Czochralski process, where a seed crystal is dipped into molten silicon and slowly pulled out while rotating to form an ingot.
For polycrystalline silicon, molten silicon is poured into a mold and cooled, forming a block of multiple crystals.
Wafer Production: The silicon ingots are sliced into thin wafers using diamond-wire saws. These wafers are typically 160-200 microns thick.
Doping: The wafers are treated with phosphorus (n-type doping) and boron (p-type doping) to create a p-n junction, the core of the photovoltaic effect. This doping process ensures the movement of electrons when sunlight strikes the cell.
Surface Texturing: The wafer surfaces are etched to create a texture that minimizes reflection and maximizes sunlight absorption.
Anti-Reflective Coating: A thin anti-reflective layer is applied to enhance light absorption by reducing the amount of sunlight reflected away.
Metal Contacts: Fine metal lines (usually silver) are printed on the front of the cell to act as conductors for collecting electricity. A thicker metal layer is added to the back to complete the electrical circuit.
Encapsulation: Multiple cells are interconnected to form a solar panel. These cells are laminated with protective materials like ethylene vinyl acetate (EVA) and enclosed between a tempered glass front and a durable polymer back sheet for protection.
Technological Highlights of Solar Products
Companies like Solight Design have revolutionized the application of solar technology with their innovative patented thin solar panel with a dual function integrating the lamps circuit.
Solar-powered origami lights have several features:
Portable and Collapsible: Solar origami lights, such as the SolarPuff, are designed to be collapsible and lightweight, with its unique origami design, making them highly portable and easy to store. These lights can be folded flat and expanded when in use, offering a practical solution for both everyday use and emergency situations.
Durability: Made from water-resistant, UV-resistant, and recyclable materials, Solar products are built to withstand various environmental conditions, ensuring long-term usability and reducing the need for frequent replacements.
Efficient Solar Panels: The embedded solar panels are highly efficient, capable of charging the internal battery fully with just a few hours of sunlight exposure. This efficiency ensures that the lights are ready to use whenever needed, without reliance on external power sources.
Features of advanced battery storage:
Lithium-ion batteries: Lamps are equipped with rechargeable lithium-ion batteries, which have a high energy density and long life cycle. These batteries store the solar energy collected during the day, allowing the lights to function at night or during periods without direct sunlight.
Energy management systems: Intelligent energy management systems are integrated into the devices to optimize the charging and discharging cycles, ensuring maximum battery life and consistent performance.
Eco-friendly materials feature sustainable construction. The materials used in solar products are not only durable but also environmentally friendly. The use of recyclable plastics and non-toxic components underscores the company’s commitment to sustainability and reducing environmental impact.
Mitigation of Carbon Emissions
By replacing traditional, carbon-emitting energy sources with solar-powered alternatives, solar products play a significant role in mitigating carbon emissions. Each solar light displaces the need for kerosene lamps or battery-powered flashlights, both of which contribute to CO2 emissions.
According to the United Nations Environment Programme, replacing one kerosene lamp with a solar-powered alternative can prevent approximately 0.2 tons of CO2 emissions per year.
In the U.S., the average CO2 emission factor for electricity generation is approximately 0.453 kg of CO2 per kWh. Two LED light bulbs = 98 pounds (so in five years 490 pounds and lifetime of 80 years = 7,840 pounds; then multiply that by US population 327.2 million). That’s 3.2 billion pounds of CO2 each year just for LED bulbs. An incandescent light bulb equals 336 pounds of CO2 eight hours/per year.
Charging a smart phone just one hour a day, each day for one year, produces more carbon emissions than two round-trip flights between London and Glasgow. That’s 1.4 tons of CO2, and 275 million tons of CO2e annually just in the U.S. – and 13 megatons of CO2e globally.
—Alice Chun is CEO of Solight Design.
