Home News Multiprocess Power Source
ESAB Welding & Cutting Products introduced Warrior, a new multiprocess power source and feeder designed for processes including energy generation construction, pipe welding, general fabrication, and repair and maintenance. Designed for GMAW (MIG), FCAW (flux-cored), SMAW (stick), and GTAW (TIG) welding as well as ACAG (arc gouging), Warrior delivers up to 500 amps at 60% duty cycle.
Designed with input from welders, Warrior carbon arc gouges up to 3/8-inch welds using 0.030- to 5/64-inch flux-core and solid wires, and has 7018 and 6010 cellulosic capability. Warrior’s durable external body withstands the elements. Its IP23 rating is designed to endure harsh outdoor environments—including up to 60-degree driving rain. Ergonomically designed handles are built to withstand mechanical hoisting, and double-bend 14-gauge steel side panels protect it against collisions and drops. (http://www.esabna.com)
