Home Press Releases GEDA Promotes Innovative Hoist for Wind Turbines at bauma Event
At bauma 2025, touted as the world’s leading trade fair for construction machinery, building material machines, mining machines, construction vehicles, and construction equipment, which was held at the exhibition center in Munich, Germany, April 7–13, 2025, GEDA presented itself under the motto “UNLIMITED SOLUTIONS.” The slogan launches a clear message: GEDA offers a tailored solution for every need. The company’s versatile product portfolio, comprehensive service, and innovative digital tools form a convincing all-around package that leaves nothing to be desired. GEDA stands as a partner for solutions that combine both quality and flexibility.
Meanwhile, the opening of GEDA’s new administrative building in Asbach-Bäumenheim, Bavaria, also marks a significant step forward. The thoughtfully designed and sustainable building sets new standards with the goal of achieving DNGB Gold certification. The concept of sustainability is firmly embedded in GEDA’s culture and is reflected both in the new building and in the company’s products. Many devices from GEDA, for instance, are characterized by features such as energy recovery, thereby contributing to the conservation of resources.
Among notable power industry offerings promoted at bauma 2025 was the GEDA SH 250 W, a hoist designed for wind turbines. This battery-powered lift enables sustainable and independent operation, with excess energy efficiently fed back into the batteries. This not only helps reduce operating costs but also increases the elevator’s lifespan by minimizing both maintenance and service costs. Compared to conventional lifts with steel cables, operating costs and downtime are significantly reduced.
The GEDA SH 250 W is a robust rack-and-pinion lift specifically designed for use in wind turbines (Figure 1). Its stable guide ensures an extremely smooth ride, even during the construction phase of wind turbines.
1. The GEDA SH 250 W has a two-person lift capability with load capacity of 250 kilograms (about 550 pounds). Courtesy: GEDA GmbH
Another highlight is its battery-powered concept, which allows for the return of excess energy—a further step toward sustainable resource use. The integrated remote diagnostics feature ensures fast service and immediate availability, while the “Plug-and-Play” system allows for easy and quick installation. Additionally, the GEDA SH 250 W can be easily retrofitted into existing wind turbines (Figure 2), making it a flexible solution for both new and existing projects. With the GEDA SH 250 W, GEDA provides an innovative solution that meets the demands of the wind power industry while ensuring high efficiency and low operating costs.
2. The GEDA SH 250 W can reach heights of 210 meters (about 689 feet) and travels at speeds up to 21 meters/minute (about 69 feet/minute). Courtesy: GEDA GmbH
About GEDA
In the construction machinery sector and at global construction sites, GEDA has been renowned for offering unique quality and made-in-Germany expertise for over 90 years. The company has developed a comprehensive product range over the decades: From compact 60 kg wire rope lifts for workmen and versatile transport platforms to person and material hoists—the GEDA range could not be any broader. This is complemented by building maintenance unit and industrial elevator product ranges for permanent use in power stations and cement works, offshore plants, etc.
