Home Legal & Regulatory FERC Offers Guidance on NERC Penalty Notices
The Federal Energy Regulatory Commission (FERC) recently provided important guidance to the North American Electric Reliability Corp. (NERC), "Regional Entities" (the NERC reliability councils), and the industry on how it will conduct future reviews of penalty notices in a proceeding involving load shedding by California’s Turlock Irrigation District (Turlock) when a vegetation-related outage occurred on the public power system’s transmission facilities. FERC’s order is noteworthy not only because it provides insight into its thinking on issues such as penalties when load is shed and mitigating factors, but also because FERC explicitly required that the regional entities it regulates conduct "spot checks" of a future compliance and report the results to FERC for the commission to potentially take additional enforcement action.
This controversial proceeding started in 2010 when FERC took the unusual step of initiating, on its own motion, a review of a NERC notice of penalty against Turlock. At issue was an $80,000 penalty, agreed to in a settlement between the Western Electricity Coordinating Council (WECC) and Turlock, for alleged violations of eight Reliability Standards, including "Reliability Standard FAC-003-1 Requirement R2" pertaining to vegetation management. At the time FERC initiated its review, it was concerned that the penalty amount was too low, particularly in a situation in which a vegetation-caused outage led to load shedding in the service areas of Turlock and the Modesto Irrigation District (Modesto). Appearing inconsistent, NERC previously assessed higher penalty amounts against other entities for violations of the same vegetation management requirement when those entities did not shed load.
Ultimately, FERC affirmed the Turlock penalty amount because the penalty related to a violation that occurred during the "initial period" in 2007 when mandatory Reliability Standards had only recently taken effect, and FERC had granted NERC greater enforcement discretion. FERC also directed WECC to conduct spot checks for the purpose of testing continued compliance by Turlock—and, if appropriate, Modesto (which co-owned transmission lines with Turlock)—with Reliability Standards relating to the events that led to the loss of load and to report the results to FERC staff. Once WECC submits its report, FERC will determine whether to exercise its authority to issue an order, on its own motion, requiring compliance with the Reliability Standards.
Although FERC affirmed the penalty amount, it nonetheless responded to issues raised in comments to provide notice of guiding principles applicable to future commission actions on penalty notices. FERC addressed the adequacy of the record filed by NERC, the assessment of penalties when load is and is not shed, and factors that will and will not mitigate penalty amounts, such as self-reporting, cooperation, the nature and size of the registered entity, and human error.
First, FERC expressed concern about the adequacy of the record filed by NERC. FERC noted that in the absence of its review, FERC would not have discovered several critical facts, including the fact that a transmission protection system was incorrectly toggled off due to an alleged "human error." FERC also criticized NERC’s initial filing for failing to include sufficient information about system conditions on the date the vegetation contact and loss of load occurred, including conditions within the California Independent System Operator footprint.
Going forward, FERC directed NERC to file a complete and accurate record for each notice of penalty, whether it reflects an adjudicated determination or a settlement with the registered entity. FERC expects that when a loss of load results from a violation, the regional entity and NERC will clearly describe relevant system conditions and whether (and, if so, how) the unnecessary loss of load led to or required changes in these conditions. FERC believes this description will help determine harm resulting from the loss of load.
Second, FERC addressed the imposition of penalties when load is shed. Many commenters urged the commission to refrain from penalizing entities for shedding load because it would discourage system operators from taking this action when necessary to prevent a problem from spreading. In response, FERC stated that load shedding alone is not a violation and that it may be necessary to comply with a Reliability Standard as a last resort to contain system emergencies and prevent cascading. FERC further stated that, if the Reliability Standards require load shedding, system operators should shed load and FERC will not approve or assess a penalty for such conduct. If, however, load shedding results from a violation of a Reliability Standard, FERC stated that the penalty for the violation should take into account the lost load because the violation creates a more serious risk, due to the actual harm that results, than a similar violation that did not necessitate load shedding. FERC also stated that the failure to shed load when required could lead to greater load loss, damage to assets, and an increase in the penalty.
Turlock asserted that there was no actual harm from the loss of load because no customers suffered damages, injuries, or fatalities. FERC, however, determined that a loss of load caused by a violation of a Reliability Standard results in harm that is unnecessary and avoidable. Accordingly, the commission will consider the quantity of load lost from a Reliability Standard violation in its analysis of harm when determining appropriate penalty levels.
Turlock also argued that NERC’s Sanction Guidelines do not allow load shedding to be considered in a penalty determination. FERC disagreed. While harm resulting from a violation is not specifically included in the Sanction Guidelines’ list of "adjustment factors" that may lower or increase a base penalty amount, FERC found that a regional entity and NERC may consider other appropriate factors. FERC concluded that actual harm resulting from a violation of a Reliability Standard is an appropriate penalty adjustment factor if a regional entity or NERC does not consider such harm in setting a base penalty amount.
Third, FERC addressed other factors that can potentially lower penalty amounts. FERC recognized that Turlock took some actions after the load shed event to remedy the problem, but FERC did not appear to be persuaded that those actions warranted a reduction in the penalty amount. FERC generally stated that an entity’s efforts to achieve or maintain compliance with Reliability Standards should not be the basis for a reduction in the penalty amount for a violation; rather, only an entity’s significantly enhanced efforts that go beyond what is required to attain compliance may be considered in the penalty determination.
FERC also disagreed with Turlock’s contention that it self-reported the alleged violation. Distinguishing self-reporting from cooperation, FERC found that Turlock fulfilled the notification requirements by informing WECC that it experienced a loss of firm load as a result of a vegetation contact and later cooperated with WECC by providing additional information about the disturbance on its system. FERC observed that "Reliability Standard EOP-004-1 R3 and Attachment 1-EOP-004 require a registered entity to report certain disturbances including, among others, those that result in firm load shedding of 100 MW or more to maintain the reliability of the bulk electric system." The record showed that Turlock submitted a notification to WECC pursuant to EOP-004-1 R3 using a NERC Preliminary Disturbance Report Form that instructs the submitter, among other things, to identify the cause of the disturbance. Thereafter, Turlock promptly provided additional information to WECC. Because Turlock was required to report the event, FERC concluded that it was not entitled to a self-reporting credit. FERC stated that when a registered entity informs a regional entity of a potential violation through a report required more quickly by another standard than by the one that the registered entity may have violated, it will expect the regional entity and NERC to remove self-reporting as a mitigating factor when assessing a penalty amount. However, the regional entity and NERC may recognize the registered entity’s cooperation after reporting as a separate mitigating factor in the notice of penalty determination, if justified.
Fourth, FERC rejected Turlock’s argument that a smaller penalty than was assessed against other entities for violations of the same requirement was warranted because Turlock is a smaller, public entity. The commission acknowledged that, in Order No. 672, it stated that "the relative size of an entity or its financial ability [to pay a penalty] is a factor that the ERO or a Regional Entity may consider when developing penalty guidelines or determining an appropriate penalty in a particular case." In Turlock’s case, FERC found that a lower penalty than assessed to other violators of the same requirement (which did not shed load) was not warranted simply because Turlock is a public entity or smaller in size. FERC specifically disagreed with Turlock’s position that the commission should measure the size of an entity by the number of miles of transmission lines it operates and its interconnections with the bulk-power system. Rather, FERC stated that it intends to determine size by looking at factors such as the number of employees; the annual revenue, profits, and budget of the organization; the number of separate operating divisions or units within the organization; and the corporate structure of the organization. While an entity’s financial status could reflect its ability to pay, FERC generally will not consider the size and nature of the registered entity as the most important factor in reviewing penalty notices.
Finally, FERC rejected an argument that a smaller penalty should apply to Turlock because the violation allegedly resulted from human error. FERC found that violations resulting from "human error" can lead to significant adverse effects to the bulk-power system, including massive load shedding. FERC therefore would not decrease the penalty amount, reasoning that the possibility of a significant monetary penalty for a violation of a Reliability Standard resulting from human error provides an incentive for registered entities to create and implement robust training and compliance programs and procedures to make human errors less likely.
Debbie Swanstrom is an attorney in the FERC practice at the Washington law firm of Patton Boggs, where a version of this article originally appeared.
