Home News Electric Wire Rope Hoists
Harrington Hoists launched the RHN Series, a new line of electric wire rope hoists, offered in two configurations: the deck/base-mounted hoist in 2–20 metric tons and ultra-low-headroom trolley hoist in 2–15 metric tons. Both versions are dual speed. The deck/base-mounted hoist features a compact, modular design that is perfect for stationary applications or combined with a double girder trolley for double-girder crane systems. The ultra-low-headroom trolley hoist is ideal for top-running and underhung overhead bridge cranes. The compact body and short end approach result in the longest hook travel possible in facilities with limited space. The hoists, which require minimal maintenance, offer a lubricated gear box and an electromagnetic brake that never needs adjustment. Key features include a heavy-duty fan-cooled motor, adjustable geared limit switch, load limiter, secondary block operated limit switch and a motor management device equipped with an hour meter and counter. (http://www.harringtonhoists.com)
