Home Coal DOE Selects Seven Projects for CO2 Utilization Funding
The U.S. Department of Energy’s (DOE’s) Office of Fossil Energy has awarded a total of $5.9 million to seven projects focused on novel uses of carbon dioxide (CO2).
The projects were selected under the DOE’s carbon storage program. “This portfolio will develop and test novel approaches that convert CO2 captured from coal-fired power plants to useable products. The projects will also explore ways to use captured CO2 in areas where high-volume uses, like enhanced oil recovery, may not be optimal or the use could partially offset the cost of carbon capture technologies,” according to a February 22 department press release.
The projects fall under three categories: biological-based concepts for beneficial use of CO2; mineralization concepts utilizing CO2 with industrial wastes; and novel physical and chemical processes for beneficial use of CO2.
Five of the selected projects are in the third category:
  • The University of Delaware will receive $800,000 in DOE funding to research electrochemical conversion of carbon dioxide to alcohols;
  • The Gas Technology Institute of Des Plaines, Ill., will research high energy systems for transforming CO2 to valuable products with $799,997 in DOE funding;
  • The Gas Technology Institute will receive an additional $799,807 to explore the development of a nano-engineered catalyst supported on ceramic hollow fibers for the utilization of CO2 in dry reforming to produce syngas;
  • TDA Research will develop a new process for CO2 conversion to fuel with $799,985 from the department; and
  • Southern Research will research a low-temperature process utilizing a nano-engineered catalyst for olefin production from coal-derived flue gas with DOE funding of $799,442.
Only one project was selected in each of the first and second categories. With $999,833 in DOE funding, the University of Kentucky Research Foundation will research the potential to convert CO2 from coal plants to bioplastics, chemicals, and fuels. In the second category, the University of California received $999,999 in DOE funding to create “CO2 Negative” concrete.
Abby L. Harvey is a POWER reporter.
