The electric sector is standing at a pivotal moment. Utilities are no longer observers in the renewable transformation but instead are becoming direct owners and operators of technologies that were once primarily developed, financed, and managed by third-party developers. Among these technologies, battery energy storage systems (BESS) are moving to the center of long-term generation and grid reliability strategies. While the operational value of BESS is widely recognized, the operational complexity that comes with utility ownership is often underestimated. As more utilities transition from purchasing storage services to integrating storage assets into their portfolios, the industry is discovering that success hinges not only on hardware deployment but also on thoughtful integration across operational technology, cybersecurity, compliance, and enterprise processes.
A Fundamental Shift in Ownership and Responsibility
Utilities are increasingly looking at renewable resources such as BESS as assets to own and operate. This represents a significant departure from earlier deployment models where independent power providers (IPPs) built, owned, and maintained many large-scale storage and renewable facilities. Under those models, utilities typically interacted with storage systems primarily through power purchase agreements or interconnection points. The IPP carried much of the responsibility for system integration, monitoring, and life cycle management.
Utility ownership changes that dynamic entirely. Once BESS assets move into a utility’s generation fleet, they must be treated as mission-critical infrastructure. The assets should be woven into dispatch operations, comply with regulatory standards, and operate within the same reliability frameworks that govern traditional generation. This introduces a wide range of technical and operational considerations that IPPs historically did not need to address in the same way.
For optimal success, utilities must integrate these systems into internal networks, operational platforms, and security frameworks. BESS operations should also be aligned with grid reliability standards, market participation strategies, and enterprise data ecosystems. The shift from power purchaser to asset owner introduces responsibilities that extend far beyond installing batteries and connecting them to the grid.
The Integration Challenge
Merging BESS into utility environments involves far more than physical interconnection. It requires seamless coordination across network integration, security integration, distributed control system (DCS) integration, operations center development, process design, and regulatory compliance. Each of these areas introduces unique challenges, and collectively form one of the most significant barriers to successful BESS deployment.
One of the first challenges utilities encounter is network integration. BESS facilities generate substantial operational data that must be transmitted securely and reliably between field equipment, operations centers, and enterprise systems. Existing utility communication infrastructures were often designed around traditional generation plants with predictable data flows and standardized protocols. BESS platforms frequently rely on newer communication architectures that introduce different bandwidth, latency, and security requirements.
Security integration presents another major hurdle. Storage systems often incorporate modern digital control platforms that expand the attack surface of operational technology environments. Utilities must apply rigorous cybersecurity controls that align with regulatory expectations while accounting for the unique characteristics of storage technology. The intersection of new vendor platforms and legacy utility environments can create vulnerabilities if cybersecurity is not addressed early in project planning.
DCS integration is also frequently more complicated than expected. Traditional generation assets typically rely on well-established control architectures with standardized data structures and operational workflows. BESS platforms, however, often use vendor-specific control logic, proprietary interfaces, and modular software environments. Integrating these systems into an existing DCS can require significant customization and data mapping, particularly when storage resources must operate with thermal generation or renewable generation.
Operations center integration adds another layer of complexity. Utilities must determine whether BESS assets will be monitored and controlled through existing control rooms or through newly established remote operations centers. Each approach carries implications for staffing, training, and operational procedures. Without clearly defined monitoring and response frameworks, utilities risk reduced visibility into system performance and reliability.
Existing processes and technologies within utilities also require modification. Maintenance practices, asset management programs, and compliance documentation were built around conventional generation models. Storage systems introduce new maintenance cycles, software-driven performance characteristics, and vendor-dependent life cycle requirements. Without adapting existing processes, utilities may struggle to maintain system reliability and regulatory compliance.
Compounding these challenges is the reality that many BESS control systems differ fundamentally from traditional generation control platforms. Storage systems rely heavily on software orchestration, real-time state-of-charge management, and rapid response algorithms. These capabilities offer significant grid value but also demand new operational approaches. Utilities must recognize that applying traditional generation playbooks to storage resources can create operational blind spots.
Building Strong Foundations Through Strategic Requirements
Utilities that successfully deploy BESS assets typically begin with strong procurement and requirements development processes. Requirements must be tailored specifically to the operational technology and cybersecurity characteristics of storage systems. Generic generation procurement templates rarely capture the nuances necessary for effective BESS integration.
One critical consideration involves defining generation owner and generation operator roles for both individual units and aggregated storage assets. These designations influence compliance responsibilities, operational accountability, and reporting obligations. Clear role definitions prevent confusion during audits and operational events.
Accountability for maintenance, monitoring, and daily operations must also be established early. Storage systems often involve multiple vendors, integrators, and service providers. Without clearly defined accountability structures, operational gaps can emerge during system failures or performance degradation.
Communication network integration requirements must be detailed and technically specific. Utilities should define bandwidth expectations, communication protocols, redundancy requirements, and remote access controls. These requirements influence both system reliability and cybersecurity posture.
Security requirements must address both physical and cyber domains. Physical security considerations include site access controls, surveillance systems, and tamper detection. Cybersecurity requirements should address authentication methods, network segmentation, vulnerability management, and incident response integration with existing utility security programs. Data collection, storage, and accessibility requirements represent another foundational element. Storage systems generate operational data that supports dispatch decisions, performance analytics, and compliance reporting. Utilities must define data retention periods, data ownership models, and integration pathways into enterprise analytics platforms.
DCS integration requirements must also be explicitly documented when integration with existing control rooms is anticipated. This includes identifying required data points, control commands, and alarm parameters. Early definition reduces integration delays and limits costly redesign efforts.
Integration with dispatch systems, marketing platforms, and metering infrastructure is equally important. Storage assets frequently participate in energy markets, capacity programs, and ancillary service markets. Without proper integration, utilities may lose opportunities to optimize storage revenue streams.
Alerting and monitoring requirements must define how operational anomalies are detected, communicated, and escalated. Storage systems can transition between operating states rapidly. Real-time alerting frameworks support faster response and reduce operational risk.
Software update management is another critical area. Storage systems rely heavily on vendor software updates to maintain performance and address vulnerabilities. Utilities must establish update testing protocols, deployment approval workflows, and rollback procedures.
Utilities should also require the ability to assess cyber vulnerabilities and implement mitigation strategies throughout the system lifecycle. Vendor collaboration during vulnerability management strengthens overall system resilience.
Finally, testing and emulation environments provide a safe space to validate integrations, software updates, and operational scenarios. These environments reduce operational disruptions and provide valuable training opportunities for operations personnel.
Contract Structures Reflect Operational Reality
Strong requirements alone are not sufficient. Contracts must incorporate these requirements in precise and enforceable language. Vague contractual language frequently leads to integration delays, operational conflicts, and compliance gaps.
Contracts should explicitly reference organizational policies, operational systems, and compliance frameworks. If a utility operates under specific North American Electric Reliability Corporation (NERC) controls, those controls should be referenced within vendor obligations. Aligning contractual language with regulatory frameworks strengthens accountability and simplifies audit preparation.
When integration with a specific DCS is expected, contracts should identify system versions, required data points, and communication interfaces. This level of detail reduces ambiguity and provides vendors with clear technical expectations.
Cybersecurity policies such as access management, credential management, and data protection standards must also be included in contractual requirements. Storage vendors often operate across multiple industry sectors, and their default security configurations may not align with utility regulatory obligations.
Network connectivity requirements should be clearly documented, including demarcation points, network ownership, and communication redundancy expectations. Similarly, system integration requirements should identify enterprise platforms that require data exchange or control coordination.
Early Engagement Drives Long-Term Success
Engaging operational technology and cybersecurity resources early in project development significantly improves deployment outcomes. These teams bring practical insights into system integration challenges, compliance obligations, and operational workflows. Their early involvement allows utilities to identify potential conflicts before equipment is procured or installed.
Early engagement also supports more accurate cost estimation and project scheduling. Integration challenges discovered late in project timelines frequently introduce expensive redesign efforts and commissioning delays.
Utilities should also evaluate whether new operations centers or remote monitoring capabilities will be required to support expanding storage portfolios. Planning for future fleet growth allows utilities to build scalable monitoring frameworks rather than deploying isolated monitoring solutions for individual projects.
BESS and other emerging renewable technologies represent complex digital ecosystems with expanding operational footprints. They introduce new data streams, software dependencies, and cybersecurity considerations that extend far beyond traditional generation models.
Ignoring network, data, security, compliance, and integration requirements places projects at significant risk. These areas are not secondary considerations but rather form the operational backbone that allows storage systems to deliver grid value safely and reliably.
Thoughtful planning must begin during requirements development and continue through procurement, deployment, and operational phases. Operational technology considerations should be embedded into contracts, technical specifications, and project governance frameworks from the start.
Failure to address these factors can produce substantial project delays and operational risk. In one documented deployment, inadequate planning around system integrations and cybersecurity challenges contributed to more than 14 months of project delays. Such delays affect not only project economics but also grid reliability strategies and regulatory commitments.
The Path Forward
The transition toward utility-owned BESS assets represents an exciting step forward in grid modernization and renewable integration. Storage technology offers unparalleled flexibility, rapid response capability, and market participation opportunities. However, the operational complexity that accompanies these benefits demands disciplined planning and cross-functional collaboration.
Utilities that approach BESS deployment as a comprehensive integration challenge rather than a standalone generation project will be better positioned for long-term success. By developing tailored requirements, constructing precise contracts, engaging operational technology and cybersecurity teams early, and planning for scalable operations, utilities can unlock the full value of storage technology while maintaining reliability and compliance.
The renewable transition is accelerating, and storage will play a defining role in shaping the future grid. The organizations that succeed will be those that recognize that batteries are not just energy assets but also digital infrastructure that must operate seamlessly within the broader utility ecosystem.
—Nathan Brown is a director of operational technology services at 1898 & Co., part of Burns & McDonnell.
