Home Press Releases New remote calibrator for combustible gas detectors
LAKE FOREST, CA— January 27, 2010—The new Remote Gas Calibrator for the IR400 Infrared Point Gas Detector from General Monitors simplifies the time-consuming process of performing combustible gas detector calibration tests and checks. This is ideal for drilling rigs, compressor stations, refineries, aircraft hangars, wharehouses and more!
Some gases are lighter than air, and for this reason it is common practice install IR gas detectors in ceilings, ducts, and other spaces where gas accumulation occurs. Performing routine maintenance on these devices, however, is often difficult and requires scaffolding, ladders, or lifts to bring technicians to the detectors.
The new RGC-IR remote calibrator makes it much easier to calibrate remote mounted infrared gas detectors.  It permits users to test and calibrate the IR400 and its predecessor, the IR2100, from as far away as 100 feet (31 meters). The RGC-IR does not affect sensor response, as evidenced by T50 response times of 6 – 7 seconds and T90 response times of 10 seconds and is suitable for operation at maximum air velocities of 13 meters/second (30 miles/hour).
The RGC-IR, along with the IR400 gas detector, is suitable for a wide range of applications including drilling rigs, compressor stations and refineries.  Easy to install and use, the RGC-IR requires no electrical wiring or connectors.
About General Monitors
Founded in 1961, General Monitors is a leading manufacturer of gas and flame detection monitoring products.  The company is third-party certified to ISO 9001:2008 requirements.  Corporate headquarters in Lake Forest, California comprise a modern engineering design center, R&D, manufacturing, sales and service complex.  A facility in Galway, Ireland supports the EU with engineering design, R&D and manufacturing.  Sales and service offices are maintained in Houston, Texas, Singapore, the United Arab Emirates, and the United Kingdom.
Company Contact
Angela Sauceda, Marcom Manager
Tel: 949-581-4464
etech@generalmonitors.com
Agency Contact
Randy Brown
Tel: 909-335-1941
brownr@rbmarketing.com
General Monitors
26776 Simpatica Circle, Lake Forest, CA 92630
www.generalmonitors.com
Tel:  1-800-330-9161
Tel:  949-581-4464
Fax: 949-581-1151
