Home Press Releases IMI Launches High Temperature Pressure Sensors for Gas Turbine Monitoring
Depew, New York, USA – November 15, 2010 – IMI Sensors, a division of PCB Piezotronics, Inc., announces the global launch of the company’s Series 176 high-temperature pressure sensors for gas turbine monitoring. When directly mounted to a gas turbine’s combustor, the Series 176 high-temperature pressure sensors provide 24/7, consistent, reliable combustion dynamics data monitoring.
IMI’s Series 176 high-temperature pressure sensors detect and measure dynamic pressure phenomena and combustion instability in the extreme heat environments (+986 °F, +530 °C) generated by today’s gas turbines. These sensors are also ATEX and CSA certified for use in hazardous areas. The Series 176 high-temperature pressure sensors are ideally suited for gas turbine monitoring with sensitivities to 17 pC/psi (2.5 pC/kPa) and ranges from 20 psi (140 kPa) dynamic to 400 psi (2760 kPa) static.
By mounting the Series 176 high-temperature pressure sensors to the combustor, gas turbine operators can rely on critical diagnostics, part fatigue analysis, and the ability to continuously monitor and control emissions. Operators also save time during combustion inspections and overhauls due to the elimination of tubing and a purging system. In addition, the high frequency capability of the Series 176 sensors enables the use of auto-tuning and on-line diagnostic monitoring systems. These sensors also provide an output that can easily connect to legacy combustion dynamics monitoring systems.
About IMI Sensors
IMI Sensors is dedicated to addressing the machinery vibration sensing needs for condition monitoring, predictive maintenance, and process control requirements. All IMI sensors and vibration switches are designed to withstand the rigors of harsh industrial environments. Included are sensors that interface directly with vibration data collectors and analysis equipment, as well as process monitoring equipment, PLC, DCS, alarm, and SCADA systems.  For more information about IMI Sensors please call us anytime at 800-959-4464, or visit www.imi-sensors.com.
About PCB
PCB Piezotronics, Inc. is a global leader in the design and manufacture of force, torque, load, strain, pressure, acoustic and vibration sensors, as well as the pioneer of ICP® technology.  This instrumentation is used for test, measurement, monitoring, and feedback control requirements in automotive, aerospace, industrial, R&D, military, educational, commercial, and OEM applications. From ready-to-ship stock products, to custom-made specials, PCB® proudly stands behind all products with services you value most, including 24-hour customer support, a strategic global distribution network, and the industry’s only commitment to Total Customer Satisfaction.  For more information about PCB® visit www.pcb.com.
