Home News New Burner Management System
Siemens Industry Inc. introduced two new SIMATIC Burner Management Systems (BMS) to give end users greater flexibility to cost-effectively comply with revised 2011 burner standards. Designed with TUV-certified hardware and customizable software, the compact BMS300F and BMS151F systems comply with NFPA, IEC, and ANSI/ISA standards for single- or dual-fuel applications with single or multiple burners. The models are also capable of meeting up to SIL-3 with appropriate field devices.
The BMS models are designed in accordance with the technical requirements listed in both NFPA 85 and 86 standards for programmable logic solvers (section 4.11 of NFPA 85 and section 8.3 of NFPA 86). All critical BMS functions are managed via IEC 61508 compliant components up to SIL-3, thereby ensuring safety metrics are met. These systems are also compliant with ISA S84.00.01-2004 and IEC 61511. An optional TUV-certified burner blocks library is also available. (http://www.usa.siemens.com/fa-bms)
