Home News Laser Pulley Alignment Tool
Seiffert Industrial’s new laser pulley alignment tool, Pulley PRO, uses a green laser beam for maximum angular resolution and for reliable and accurate readings. The lightweight and compact units magnetically attach to the inside or outside face of any pulley or sprocket and have no small parts or targets that can get lost. A laser line is projected from the device to the reflector mounted on the opposite pulley. A reference line on the reflector indicates offset and vertical angle misalignment immediately.
The Pulley PRO can measure spans up to 15 feet or better. Seiffert claims that the green laser offers several advantages over the red laser beam used for an older model, the PULLY PARTNER, because it includes a brighter, more visible laser line, enhanced optics, larger reflective surfaces, and excellent angular resolution. (www.seiffertindustrial.com)
Inclusion in New Products does not imply endorsement by POWER magazine.
