Home Press Releases Shannon’s new hydrophobic insulation blanket reduces risk of CUI, boosts safety
New hydrophobic thermal and acoustic insulation blankets reduce energy loss and/or mitigate harmful noise levels from equipment.
NORTH TONAWANDA, N.Y., April 28, 2021 /PRNewswire-PRWeb/ — Shannon Global Energy Solutions, which engineers and manufactures reusable solutions for a sustainable planet, has developed a new, hydrophobic thermal and acoustic insulation blanket to reduce energy loss and/or mitigate harmful noise levels from equipment like valves, pumps, heat exchangers, vessels and compressors with geometrically complex surfaces at refineries and processing plants. Shannon’s new blanket designs – which contain Lewco Super Mat®, a PTFE-impregnated Type-E needled and felted fiberglass blanket insulation – do not require workers to wear a mask while manufacturing or installing the material. Super Mat helps mitigate CUI due to its water-repelling properties.
The Shannon Hydrophobic Thermal Blanket, designs LT450TT-HES and LT450TT-HS, and Shannon Hydrophobic Acoustic Blanket, designs LT450A-TT-HES and LT450A-TT-HS, have an insulating core made of hydrophobic Super Mat consisting solely of PTFE and E-glass fiber, which means there is no amorphous silica particulate or additive that can escape as dust, posing a health risk. Shannon hydrophobic acoustic blankets reduce harmful noise levels by up to 15 dBA. Depending on thickness, Shannon calculates the surface temperature of its thermal blanket when wrapped around a component operating at 450 F (232 C) will range from 108 F (42 C) to 135 F (57 C). Shannon blanket designs encapsulate the Super Mat insulation core with various jacketing materials, including PTFE-impregnated fiberglass cloth commonly used for applications at processing plants.
The PTFE coating of every glass fiber gives Super Mat its hydrophobicity, or ability to repel water. Hydrophobic insulation reduces the risk of CUI by significantly reducing or eliminating the steel substrate’s duration of wetness caused by water-soaked insulation. When water absorbent insulation becomes wet, it not only lacks the ability to conserve thermal energy, but also holds that water against the equipment, which increases the risk of CUI. Super Mat’s hydrophobic performance is validated by ASTM test methods C1511 and C1763.
“If insulation gets wet enough, it will corrode a steel substrate and lead to thermal efficiency degradation,” said Monica Chauviere, president of Monicorr, Inc., a consultancy providing expertise on CUI and thermal insulation, which she founded after retiring as an ExxonMobil engineer. “A higher volume percentage of water inside the insulation requires more heat energy to reach vaporization. The insulation’s deteriorating thermal conductivity offsets the accumulating heat energy, which comes from the equipment, and creates this double whammy.”
“Since the 1970s, blanket manufacturers have used E-glass insulation mat because of its quality and safety; it doesn’t require respiratory masks and body protection to avoid unwanted exposure,” said Frank Kovacs, president and CEO of Shannon. “E-glass is the most widely accepted and specified insulation core material because it’s the safest, most durable. It’s one reason our blankets have earned a reputation for high quality.”
About Shannon Global Energy Solutions
Since 1988, Shannon has engineered and manufactured insulation solutions for energy conservation, thermal efficiency, noise reduction and safety. With its CAD-CNC-ERP approach from design to manufacturing and facilities in the U.S. and Europe, Shannon is the world leader for reusable and removable insulation. Visit http://www.shannonglobalenergy.com
