Home Press Releases EMERSON EXTENDS CAPABILITIES OF PH/ORP SENSORS TO MEET A BROAD RANGE OF APPLICATIONS
IRVINE, Calif. (January 19, 2010) – Emerson Process Management has released the Rosemount® Analytical Model 3900 general purpose pH/ORP sensor, designed to meet the broadest range of applications in the industry. It has the widest temperature operating range of any general purpose sensor and is the first to function at sub-zero temperatures, providing accurate measurements in applications from -10 degrees C to 100 degrees C. Each sensor is equipped for both ¾ inch and 1 inch mounting, allowing it to fit in smaller pipes, giving optimum mounting versatility in insertion, submersion and flow-through applications.
The Model 3900 features the patented AccuGlass™ sensor glass formulation which has been field-proven in premium sensors designed for rugged environments. The AccuGlass formulation exceeds industry standards and resists cracking. In addition, a unique Teflon double-junction reference electrode protects the sensor from poisoning ions. The complete encapsulation of the sensor eliminates leakage or high humidity problems found in other pH/ORP sensors.
The Model 3900 gives the user access to a wider range of more advanced diagnostics. In addition to glass diagnostics, a stainless steel solution ground allows reference diagnostics, simplifying maintenance and scheduling. The solution ground also reduces noise, makes for a highly stable measurement, and makes internal temperature compensation respond more quickly than with previous generation solutions.
The Model 3900 is a combination sensor including pH, ORP (Oxidation Reduction Potential) and temperature within the sensor body. It is designed to measure aqueous solutions in pipelines, open tanks, or ponds. The sensor is compatible with all Rosemount Analytical analyzers as well as those from other manufacturers.
About Emerson Process Management
Emerson Process Management (www.EmersonProcess.com), an Emerson business, is a leader in helping businesses automate their production, processing and distribution in the chemical, oil and gas, refining, pulp and paper, power, water and wastewater treatment, food and beverage, pharmaceutical and other industries. The company combines superior products and technology with industry-specific engineering, consulting, project management and maintenance services. Its brands include Rosemount®, PlantWeb™, Fisher®, Micro Motion®, Daniel®, DeltaV™, Ovation™, and AMS Suite.
About Emerson
Emerson (NYSE: EMR), based in St. Louis, Missouri (USA), is a global leader in bringing technology and engineering together to provide innovative solutions for customers in industrial, commercial, and consumer markets through its network power, process management, industrial automation, climate technologies, and tools and storage businesses. Sales in fiscal 2010 were $21 billion. For more information, visit www.Emerson.com
