Home News Pre-Engineered Robotic Welding Cells
ESAB Welding & Cutting Products introduced three models of the new Swift Arc series of pre-engineered, robotic welding cells: Swift Arc AL (angle-load), Swift Arc FL (front-load), and Swift Arc SL (side-load) robot cells. Each system is an economic configuration for a complete work cell and is ideal for job shops introducing robotics to their applications. The complete robotic system is delivered ready-to-weld. Just hook up the input power, gas, and wire to start welding. The state-of-the-art welding power source and wire feeder are offered as standard components, designed to minimize spatter and burn-through on thin materials. TruArc Voltage is another standard feature offered to provide accurate voltage information for critical welding. Other standard features include harmonized motion between the robot and external axes, open architecture Windows HMI, easy teaching with the PC-based controller, constant wrist orientation function, and electronic mastering for quick calibration. (http://www.esab.com)
