Home News Portable Milling Machine for Linear and Gantry Milling
The Climax LM5200 and LM6200 portable milling machines are designed with a split rail system to easily perform both linear and gantry milling with a minimum of changeovers. A rigid, modular bed design allows shorter bed sections to be combined to fit the length of the work area, without losing rigidity, and to extend the bed by two or three times its original length. With just a few simple changeouts, bed lengths can be extended to 192 inches and RAM length to 116 inches. The machines enable precision milling, drilling, and boring to be done more efficiently to meet tight tolerances.
Features include reduced-friction rail technology for continuous, nonstick slip travel throughout the entire length of the piece being machined; milling head that can be rotated 360 degrees; heavy-duty spindle design; and choice of power units for aggressive milling in any position. Applications include pump and motor mounts, compressor and heat equipment foundations, exchanger faces, sole plates, as well as other metal pieces with flat and rounded surfaces. (http://www.climaxportable.com)
