Home News Flowmeter for Utility Gases
Endress+Hauser released the Proline t-mass 150 thermal mass flowmeter for measuring gases such as compressed air, nitrogen, carbon dioxide, and argon. The flowmeter measures mass flow, gas temperature, free air delivery, and corrected volume—all without the need for pressure or temperature compensation. The t-mass 150, with its high turndown of 100:1, can reliably measure small gas quantities at very low operating pressures, making it suitable for applications such as leak detection, process control, cost allocation, analysis of flow profiles and energy management. The flowmeter operates in temperatures from –40F to 212F and pressures up to 580 psi. It measures mass flow up to 2.4 million pounds/hour with negligible pressure loss. The stainless steel flowmeter has CSAus and ex approvals for use in Class 1, Division 2 areas. (http://www.us.endress.com/t-mass-150)
