Tools for Accurate Pipe Weld Preps And Cut Time Estimates
Project managers, welding contractors, and field machinists will find that they will make their pipe welding more efficient by using weld prep tools. Quality, precision weld preps made with E.H. Wachs equipment ensures users that the welding process will consistently pass inspections time and time again, while avoiding any reprocessing of the weld prep. Wachs machine tools are built to cut, bevel, j-prep, counter bore, flange face and single point pipes from 2” to 72" O.D. and utilize a cold cutting process that eliminates the hazards related to torch cutting and grinding. This is especially important wherever volatile hydrocarbons are present.
Available online at ehwachs.com/calculators, Wachs offers online time calculators and other tools to help prepare cost estimates when bidding on pipe maintenance or pipe repair projects. Utilizing these tools, managers, contractors and machinists can better estimate labor time with the Pipe Cutting and Weld Prep Time Calculators. To see a video on how they work, go to youtube.com/ehwachs or this direct link at http://youtu.be/5rmnohfOmN0.
A long time industry favorite, Wachs cold cutting weld prep equipment products include the following: Low Clearance Split Frame (LCSF); Small Diameter Split Frame (SDSF); Heavy Duty Split Frame (HDSF); Guillotine® Pipe Saws; Trav-L-Cutter®; EP424 End Prep Machine; FF series flange facers; SDB small diameter bevelers; boiler tube bevelers; handheld valve operators; hydraulic power units and Genuine Wachs Tooling. E.H. Wachs equipment is available as rentals for short term needs. Wachs products are available at our strategically located Sales, Service and Rental Centers and though our worldwide dealer network.
For additional information, visit us at ehwachs.com. E.H. Wachs® 600 Knightsbridge Parkway Lincolnshire, IL 60069 USA +1.847.537.8800 www.ehwachs.com/Industrial-Products/.
[email protected]
