Esco Introduces MILLHOG® Boiler Tube Panel Replacement System that Offers Fast, Accurate Cutting & Membrane Removal
A saw and track system that rapidly cuts through water wall boiler tube up to 4″ O.D. to produce highly accurate and perfectly straight cuts with no HAZ (heat affect zone) has been introduced by Esco Tool
HOLLISTON, Mass., May 3, 2022 /PRNewswire-PRWeb/ — Esco Tool has introduced a saw and track system that rapidly cuts through water wall boiler tube up to 4″ O.D. to produce highly accurate and perfectly straight cuts with no HAZ (heat affect zone).
The MILLHOG® Boiler Tube Panel Replacement System features the APS-438 Saw and the EscoTrackTM System that easily attaches to a panel using weld tabs. Capable of cutting 4″ O.D. tubes horizontally perfectly straight with 1/16″ accuracy and no HAZ, the saw can then be fit with a vertical track attachment for equally fast and accurate boiler tube membrane removal.
Equipped with a 3 hp pneumatic motor that runs on 90 psi shop air and only 80 cfm, the APS-438 Saw uses proprietary reinforced fiberglass abrasive saw blades for quick cutting and long life. Fully supported by the steel track, the saw glides smoothly and the MILLHOG® Boiler Tube Panel Replacement System eliminates the need for tube rework and grinding before beveling.
The MILLHOG® Boiler Tube Panel Replacement System is priced from $6,295.00 and is available for rent. Complete pricing is available upon request.
For more information contact:
ESCO Tool
A Unit of Esco Technologies, Inc.
Matthew Brennan, Marketing Director
75 October Hill Rd.
Holliston, MA 01746
(800) 343-6926 FAX (508) 359-4145
e-mail: [email protected]
http://www.escotool.com
