Home News Ultra-Low-NOx Burner
Hamworthy Peabody Combustion introduced the ECOjet ultra-low-NOx burner. Offering ultra-low burner nitrogen oxide capacities (<30 parts per million) with little or no flue gas recirculation, the burner can be used with a full range of gaseous fuels and with package, industrial, and utility boilers, including single and multi-burner wall-fired, turbo, and other boiler types. Ignition is achieved using the highly reliable, self-cleaning, and low-maintenance Chentronics’ High Energy Direct Spark Ignitor. Burner ramp rates are not limited by speed. The burner does not require complicated control systems, special fuel, or combustion air filtration or straining. (http://www.hamworthy-peabody.com)
