Home News Remote UPS Monitoring System
AMETEK Solidstate Controls Inc. (SCI) introduced SAGE, a remote uninterruptible power supply (UPS) monitoring system that connects seamlessly with AMETEK SCI’s UPS line of products (both Ferro and PWM). With SAGE, all of the alarms and notifications from a UPS can be accessed remotely. SAGE also works in combination with SCI’s CellRx battery monitoring system, creating an environment where all power systems can be monitored remotely from a single screen. The system can connect through TCP/IP as well as Modbus, enabling the UPS data to be fed into custom systems over a standard Ethernet line. Data are exported into a neatly organized datasheet format that is password encrypted and easy to read. This plug-and-play approach also makes installation fast and easy. (www.solidstatecontrolsinc.com)
