Home News Extreme Temperature Vibrating Fork
Emerson Process Management launched a new extreme temperature version of its Rosemount 2130 vibrating fork liquid level switch that is designed for use in extreme temperatures — from – 94F to 500F (–70C to 260C). The new version includes a low-density option suitable for liquids with specific gravity down to 0.5 (500 kg/m 3). In addition to built-in fault-monitoring/self-checking diagnostics to detect corrosion of the forks or any internal or external damage or breaks in the internal electrical wiring, it features a "heartbeat" LED, which provides instant visual indication that the unit is operational. The unit requires no onsite calibration and is available in 316L stainless steel, corrosion-resistant alloy C wet side, or a range of other stainless steel and aluminum options. (www2.emersonprocess.com)
