The Solid-State Shift: Reinventing the Transformer for Modern Grids
Transformers have been the backbone of power grids for over a century, but today’s demands for renewable energy, electric vehicles, and smarter grids are exposing their limits. Enter solid-state transformers—compact, efficient, and intelligent power solutions poised to revolutionize how electricity is distributed and managed.
The push to modernize the grid is exposing critical shortcomings of a century-old workhorse—the transformer. Stemming from Michael Faraday’s groundbreaking discovery of electromagnetic induction in 1831, the first transformer systems built circa 1885 revolutionized electricity transfer, essentially by enabling the step-up of voltage for efficient long-distance transmission and subsequent step-down for safe local use. The past century has characteristically introduced more significant innovations, including the transition from single-phase to three-phase systems for higher efficiency and reduced costs in long-distance power transmission. Modern developments include ultra-high voltage designs exceeding 800 kV and innovations in high-voltage direct current (DC) converter transformers for long-distance, low-loss energy transport. Today’s transformers are incorporating advancements such as wide-bandgap semiconductors for higher efficiency, modular designs for scalability, and eco-friendly insulation materials like synthetic esters to address environmental concerns.
However, despite recent innovations, conventional transformers remain ill-suited to meet the dynamic demands of modern grids. Although their fundamental design provides a cost-effective and reliable method to convert voltage and insulation levels, they are optimized for centralized, unidirectional power systems with simple structures. At the core of their limitations, as David Pascualy, a technical expert in solid-state transformers (SSTs) and power electronics, explained to POWER, “a normal standard transformer doesn’t communicate with the grid.”
Without advanced power electronics or sensors, conventional transformers cannot actively regulate voltage, mitigate harmonic distortion, or respond dynamically to grid disturbances, he said. Additionally, their lack of integration with digital control systems and grid communication protocols prevents them from supporting intelligent grid operations, such as voltage-ampere reactive (VAR) regulation, participation in grid demand response programs, predictive maintenance, or real-time optimization.
Traditional transformers operate at low frequencies (50/60 Hz), requiring bulky cores and windings that limit scalability, reduce efficiency, and make them impractical for space-constrained applications such as urban substations or offshore wind platforms, Pascualy noted. Their reliance on oil-based insulation and cooling also introduces environmental risks, demands significant maintenance, and leaves them vulnerable to failures under extreme weather conditions or fluctuating loads.
SSTs: A New Breed of Transformers
To address these limitations, research into solid-state transformers (SSTs) has been ongoing since the 1960s. William McMurray, an engineer at General Electric, first proposed the concept of an “electronic transformer” in 1968 in a design that introduced high-frequency alternating current-to-alternating current (AC/AC) converters. The design allowed for voltage transformation using power electronic components, marking a foray away from traditional low-frequency transformers and demonstrating how high-frequency operation could enable more compact and efficient designs. The concept was later refined by contributions such as J. L. Brooks’ SST in 1980, and the Electric Power Research Institute’s (EPRI’s) introduction of the Intelligent Universal Transformer (IUT) in 1995. The IUT incorporated features such as bidirectional power flow, voltage regulation, and seamless AC/DC conversion.
According to Pascualy, recent advancements in materials and design continue to significantly enhance the performance and applicability of SSTs. Wide-bandgap semiconductors, such as silicon carbide (SiC) and gallium nitride (GaN), today enable higher switching frequencies, reduced energy losses, and improved thermal management. High-frequency transformers (HFTs), constructed with advanced magnetic materials like ferrites or amorphous alloys, further contribute to size and weight reductions while maintaining high power density and minimal energy loss. In addition, modular topologies, such as multilevel converters and dual active bridges, enhance operational flexibility, allowing SSTs to handle diverse voltage levels and operational conditions effectively. Coupled with advanced cooling technologies and intelligent control algorithms, these innovations are making them robust for modern grid applications, he said.
What Is a Solid-State Transformer?
Unlike conventional transformers that rely on heavy iron cores and low-frequency operation, solid-state transformers (SSTs) use a multi-stage architecture and high-frequency transformers (HFTs) to achieve significant improvements in size, efficiency, and functionality.
Essentially, SST functionality relates on three core stages (Figure 1).
  1. Input Stage (AC-DC Conversion). This stage converts low-frequency alternating-current (AC) into direct-current (DC), forming the foundation for high-efficiency power management. Wide-bandgap semiconductors like silicon carbide (SiC) and gallium nitride (GaN) are central to the process, offering reduced switching losses, enhanced thermal stability, and the ability to operate at higher frequencies. These innovations allow SSTs to achieve compact designs with enhanced power density. The input stage also provides reactive power compensation, which promises seamless integration with the grid and stabilizing power delivery under dynamic conditions.
  2. Isolation Stage (High-Frequency DC-DC Conversion). In this stage, an HFT isolates and adjusts voltage levels between the high- and low-voltage sides. By leveraging advanced magnetic materials (such as ferrites and amorphous alloys), HFTs minimize core losses while maintaining high thermal stability and power density. Operating at frequencies ranging from tens of kilohertz to several megahertz, the HFT significantly reduces size and weight compared to traditional transformers, making it ideal for space-constrained environments like urban substations or offshore wind platforms.
  3. Output Stage (DC-AC Conversion). This stage reconverts DC back into AC or retains it as DC, depending on the application. Supporting bidirectional power flow, the output stage enables seamless integration of distributed energy resources (DERs), energy storage systems, and renewable energy sources. Precise voltage and current regulation at this stage bolster grid stability and efficiency, positioning SSTs as intelligent nodes in modern grids.
1. Overview of the solid-state transformer (SST) infrastructure, showcasing modular design, high-frequency transformers, and advanced power electronics for compact, efficient, and bidirectional power flow. Note: AC = alternating current; DC = direct current; HV = high voltage; and LV = low voltage. Source: Agarwala et al., 2024.
Compared to conventional transformers, SST designs notably include advanced features, including modular configurations, such as multilevel converters and dual-active bridges, which enhance scalability and operational flexibility. At the same time, integrated sensors and intelligent control algorithms can enable real-time monitoring, voltage regulation, harmonic filtering, and fault isolation. SSTs also support grid communication protocols, ensuring seamless integration with renewable energy systems and DERs. Notably, however, the functionality and applicability of SSTs depends significantly on their configuration, which determines their performance in various scenarios.
One-Stage Configuration. The design involves direct AC-to-AC conversion without a DC link. While cost-effective, lightweight, and suitable for basic voltage transformation, it lacks the advanced capabilities needed for reactive power compensation and renewable energy integration. The configuration may be ideal for applications in rural and industrial settings where simple step-down voltage conversion is necessary.
Two-Stage Configuration. Incorporates a DC link on either the primary or secondary side on either the high-voltage (primary) or low-voltage (secondary) side of the transformer, enabling more advanced functions. These include, for example, reactive power compensation, improved voltage regulation, and integration with DERs and energy storage. The configuration is better suited for electric vehicle (EV) fast-charging stations, where DC conversion is critical, and for renewable energy microgrids that need reliable voltage regulation and storage integration.
Three-Stage Configuration. Features dual DC links on both the high- and low-voltage sides. While complex and costly, this configuration provides the highest level of operational flexibility, bidirectional power flow, robust reactive power management, and seamless DER connection. Applications generally envisioned include urban substations, offshore wind platforms, and data centers, which generally need compact, efficient, and highly controllable power management.
Pilot Projects and Promising Applications
As Pascualy pointed out, interest in SSTs has been growing as the urgency to outfit grids with more capable, intelligent, and dynamic solutions mounts.  But while SSTs are promising, they largely remain in the research and development phase. SST  pilot projects and pre-commercialization studies are just now emerging he noted. “Some of the big powerhouses are developing SSTs for certain aspects of their designs.”
So far, a handful of pilot projects and commercial offerings demonstrating their potential are underway, mostly focused on electric vehicle (EV) charging and solar and wind energy integration. Singapore-based startup Amperesand—a company founded by industry veterans from ABB, General Electric, Siemens and Vestas—is poised to begin a one-year proof-of-value trial in mid-2025 to demonstrate the  capabilities of its SST technology at Singapore’s port. The trial, conducted in collaboration with venture capital firm PSA unboXed, will evaluate Amperesand’s modular, SiC-based SST systems in providing efficient, compact, and bi-directional charging solutions for PSA’s electric prime mover fleet. “The modular and scalable design enables PSA to manage its electric vehicle charging facilities with greater flexibility, distributing power economically across the facility’s high-capacity dispensers,” the company said in October.
Taiwanese power electronics manufacturer Delta, meanwhile, in October 2022 demonstrated a 400-kW extremely fast EV charger that utilizes SiC MOSFET-based SST technology that operates directly from a 13.8 kVA medium-voltage input. The innovation, bolstered with a grant from the U.S. Department of Energy, was developed in collaboration with partners like General Motors and Virginia Tech. It eliminates traditional transformers, improves efficiency to 96.5%, and integrates seamlessly with renewable energy and storage systems, Delta says. Pascualy is chief commercial officer CCO at  Alderbuck Energy Inc.,  an advanced power electronics company, developing multi-stage SST technology prototypes with industry partners. EPRI in 2023 evaluated a novel SST design that could replace existing 25-kVA distribution transformers while also having voltage regulation capabilities.
Most R&D for SSTs appears largely centered on medium-voltage to low-voltage transformations, typically from a range of 13.2 kV to 15 kV down to lower voltages for various end-use applications (Figure 2), Pascualy noted. The near-term focus is “going to really be at the distribution level,” even though SST harbors a potential expansion into higher-voltage transmission, he suggested. Data centers represent another key sector looking intently at SSTs, given their potential to serve as a more efficient and integrated interface between an AC grid and a DC-powered data center, he said.
2. Solid-state transformers (SSTs) can enable efficient bidirectional power flow, renewable energy integration, and enhanced voltage regulation in modern distribution networks. Note: MV = medium voltage. Source: Shadfar et al., 2021, International Transactions on Electrical Energy Systems
Several Barriers to Overcome
While progress is encouraging, several barriers must be overcome before the technology can achieve mainstream adoption in the power industry, said Pascualy. A key challenge is cost. SSTs are more expensive than conventional transformers owing to their advanced materials, complex designs, and reliance on semiconductor-based power electronics, however they bring high value due to the additional capabilities they provide, which are not possible in standard transformers.
As with all novel power technology, achieving economies of scale and driving down manufacturing costs will be essential for making SSTs a viable option for utilities and grid operators. Reliability and field performance are also critical factors, and SSTs, with their multi-stage designs and advanced control capabilities, will need to undergo extensive testing and validation to ensure they can withstand the rigors of real-world grid operations. “You can’t possibly figure out everything that’s going to happen in the field. And you have different use cases that can produce different kind of results,” Pascualy said. “So, I think that that that is just a matter of maturing.”
The first crucial step could arrive with more widespread deployment of hybrid SSTs, which integrate the functionalities of traditional transformers and advanced SSTs to achieve modular and efficient designs. Hybrids, envisioned to feature multiple stages of voltage conversion, such as AC-DC and DC-AC, and can include both high-voltage and low-voltage DC links, are largely unavailable commercially. The University of Texas at Austin, supported by a DOE grant under the Transformer Resilience and Advanced Components (TRAC) program, has so far developed and demonstrated a 500 kVA Hybrid Solid-State Transformer (HSST) that combines dual active bridge-based SST technology with a conventional dry-type transformer. The project explored advanced capabilities such as voltage regulation, fault detection, and dynamic state estimation for modern grid applications. More research is ongoing at North Carolina State University’s FREEDM Systems Center focusing on innovations such as solid-state transformers to enhance renewable energy integration and grid efficiency.
While challenges remain in fully commercializing SST technology, Pascualy is optimistic about its potential to revolutionize grid modernization. “The grid is receiving a lot of attention right now, but we’re adding so much more to it,” he said. Collaborative efforts between technology companies, utilities, and research institutions will be crucial in driving the widespread adoption of SSTs, he predicted.
