Home Press Releases NEW HAWKEYE SIX METER FLEXIBLE VIDEO BORESCOPE FULLY PORTABLE VISUAL INSPECTION AND IMAGE CAPTURE
The new Hawkeye® 6 meter Flexible Video Borescope is the perfect choice for visual inspection when portability, easy image capture, and a long reach, are key factors. These new scopes deliver 5X higher image quality than fiber optic borescopes, and are made in the USA.
Operators can quickly and easily inspect turbine blades, combustion chambers, cooling tubes in heat exchanges, gear boxes, and more, all without the need for costly and time consuming engine and system teardown.
Fully portable, Hawkeye Flexible Video Borescopes are either 2- or 4-way articulating, and come complete with video monitor and light source, all in one easy-to-use device. Hawkeye Pro Flexible Videoscopes are either 4 mm or 6 mm in diameter, and have flexible tungsten sheaths. They are available in lengths of 1.5, 3.0, and 6.0 meters. Custom lengths are available upon request.
Hawkeye Video Borescope features include:
• Lever-controlled 2 or 4-way articulation
• Integrated monitor and light source
• Built-in USB connection and SD Memory Slot
• Miniature CMOS camera
• Fiber optic illumination
• Prices starting at $7995
Hawkeye Video Borescopes deliver the same image quality, portability, and articulation of scopes costing three times as much.
About Gradient Lens Corporation
For more than 20 years, Gradient Lens Corporation has designed, engineered, and manufactured precision optics and optical instruments.  The company’s offerings include complete lines of rigid, flexible and video Hawkeye Precision Borescopes, Luxxor Video Microscopes, and Luxxor Lighting and Video visual inspection products, and accessories.  Customers use Gradient Lens products to improve product quality, streamline inspection processes, and gain competitive advantage. www.gradientlens.com
