Home Press Releases MAN Diesel & Turbo delivers power plant engines to the Peruvian jungle
MAN Diesel & Turbo has been commissioned to supply seven diesel engines of the type 20V32/44CR. Used as gensets for a new base-load power plant, the engines will ensure power supply for the Peruvian city of Iquitos. The output from the new power plant will replace the supply from the obsolete capacity of the local network operator.
The project is logistically demanding and needs to follow a very strict timetable. Iquitos is one of the largest cities in the South American Andes country of Peru and is like an island in the midst of the tropical rain forest. There are no roads leading to the city, which is accessible only by air or river.
The delivery of the engines is therefore dependent on an adequate high-water level of the Amazon. It is only during the high-water season that the engines can be transported with a barge across the approximately two thousand kilometers up the river to Iquitos. If the high-water is missed, the window of opportunity to deliver the engines will close for an entire year.
The contractual partner of MAN Diesel & Turbo responsible for Engineering, Procurement & Construction (EPC) of the power plant is the Israeli company Telemenia. “Telemenia and MAN Diesel and Turbo look back on a more than decade-long partnership and successful cooperation in an impressive number of projects, many of which have been very demanding”, says Howard Barnes, Senior Vice President at MAN Diesel & Turbo and Global Head of Sales for the Power Plant business. “The high level of trust that is essential to work together in a project logistically as ambitious as this one comes from that long standing partnership. We have been conquering three continents together so far and I am confident there will be more in the future.” Both companies have successfully cooperated in more than ten projects on three continents over the past 15 years.
In addition to supplying the engines and most of the mechanical equipment, MAN Diesel & Turbo will also monitor the installation and take charge of the start-up operations. The seven MAN engines belong to the so-called “B.2” generation of the 32/44 CR and have additional improved performance features. The technical superiority of MAN engines was also crucial for being awarded the project: “We can generate the required electric power with fewer units than the competitors,” explains Dr. Hermann Kröger, Senior Vice President and Head of the Power Plant business at MAN Diesel & Turbo. “For customers, this means less capital investment in the acquisition and lower operating costs.”
About MAN Diesel & Turbo
MAN Diesel & Turbo SE, based in Augsburg, Germany, is the world’s leading provider of large-bore diesel engines and turbomachinery for marine and stationary applications. It designs two-stroke and four-stroke engines that are manufactured both by the company and by its licensees. The engines have power outputs ranging from 450 kW to 87 MW. MAN Diesel & Turbo also designs and manufactures gas turbines of up to 50 MW, steam turbines of up to 150 MW and compressors with volume flows of up to 1.5 million m³/h and pressures of up to 1,000 bar. The product range is rounded off by turbochargers, propellers, gas engines and chemical reactors. MAN Diesel & Turbo’s range of goods includes complete marine propulsion systems, turbomachinery units for the oil & gas as well as the process industries and complete power plant solutions. Customers receive worldwide after-sales services marketed under the MAN PrimeServ brand. The company employs around 14,500 staff at more than 100 international sites, primarily in Germany, Denmark, France, Switzerland, the Czech Republic, India and China. MAN Diesel & Turbo is a company in the Power Engineering business area of MAN SE.
