Test Your Knowledge: Water & Steam Cycle Chemistry Monitoring
Water and steam are the lifeblood of a power plant, but contamination in a water system can lead to corrosion, scaling, and pitting on critical equipment including turbines, boilers, pipes, and heat exchangers. Controlling high purity water treatment requires accurate analytical measurements of a wide range of analytics, including conductivity, dissolved oxygen, sodium, silica, and total organic carbon. This quiz will test your knowledge on these key contaminants and how you can monitor them to avoid unplanned downtime, speed up plant cycling, and prevent damage to your plant’s important equipment.
Create your own user feedback survey
