How Lithium-Ion Battery Technology Accelerates Industrial Electrification
Accelerating the transition toward low or net-zero carbon emissions is necessary to keep global warming at theoretically safe levels. In line with the U.N. Framework Convention on Climate Change, countries have been setting goals for net-zero greenhouse gas emissions by the middle of the century, with intermediate objectives and milestones by the 2030s. Corporate sustainability initiatives and government regulations that promote net-zero carbon emissions are increasing and many of America’s largest companies have established their own, more aggressive net-zero targets.
One of the fastest and perhaps most economical ways to ensure decarbonization is by using clean energy sources such as electrical power at the consumption point and moving toward renewable energy sources at the generation point.
Battery chemistry and technology, including industrial electrification, will be discussed at POWER’s Distributed Energy Conference, October 3-6 at the Gaylord Rockies resort near Denver, Colorado. There’s still time to register for the event!
Within motive power applications, the penetration of lithium-ion battery systems is relatively low but is growing fast. Motive power segments include industrial material handling (MH) equipment, such as forklifts (Figure 1) and cargo handlers, and industrial lift equipment, such as scissor lifts and electric utility bucket trucks. This equipment finds applications in power plants and related grid infrastructure (i.e., the maintenance of power lines).
Material Handling Equipment and CARB Regulations
LEK, a leading market research firm, sized the North American lithium-ion battery systems’ market value within the motive power segment alone at about $2 billion in 2021, and lithium-ion batteries makes up less than 10% of the electric MH equipment market, against more than 90% powered by lead acid battery systems. However, there is a segment-wide migration toward lithium-ion battery systems away from lead acid and internal combustion engine (ICE) power. LEK forecasts that penetration of lithium-ion battery systems is expected to continue increasing rapidly given performance advantages and decreasing prices. By 2026, lithium-ion battery systems are expected to reach one-third of the installed base, growing at a compound annual growth rate (CAGR) of about 30%, and comprising close to half of new MH equipment sales.
1. This electric forklift, or counterbalance lift truck, is an example of Class 1 Material Handling equipment. It utilizes lithium-ion batteries, rather than lead acid batteries. Courtesy: Green Cubes Technology
Lithium-ion power solutions have led and accelerated industrial electrification by providing advanced lithium-ion batteries and chargers to all electric MH equipment classes 1 through 3. Integrated aftermarket lithium-ion batteries and chargers made available through a single supplier has further eased the transition from lead acid to lithium-ion systems, ensuring a seamless route to more efficient and environment friendly operations. Adoption and implementation are simplified as aftermarket lithium-ion batteries are compatible with all electric MH equipment, and lithium-ion chargers can charge both lithium-ion and lead acid batteries. In addition to a healthy ecosystem of aftermarket lithium-ion batteries and chargers, MH original equipment manufacturers, such as Hyster-Yale Group and BYD, are offering new lift trucks that are optimized to operate with a single integrated lithium-ion battery. Lithium-ion systems offer numerous commercial and technical advantages over Lead Acid systems (as we will explore later), thereby enabling a more rapid transition to industrial electrification for power generation and distribution companies.
From 2026 onward, the California Air Resources Board (CARB) ban of sales of all new ICE forklifts with a lift capacity of 12,000 pounds (or less) is expected to come into effect. Currently the legislation is in proposal stage and not yet in effect. Phasing out of ICE forklifts from the installed base is also part of this proposal and still under development. This legislation will impact the direction of MH equipment industries, not just in California but across the nation. Given the lifespan of MH equipment is from 5 to 10 years, purchasers of MH equipment are shifting their purchases over to electric forklifts with lithium-ion battery systems, thus ensuring greater momentum and earlier compliance with this industrial electrification trend.
Electric Lift or Bucket Trucks and ACT Regulations
Electric utilities generally own a fleet of trucks that mainly include bucket trucks (Figure 2) or troubleman trucks—so named because they are used by troublemen, experts who are dispatched to investigate the causes of power outages. Electric utility bucket trucks are used to put an operator or linemen up onto a pole for repairing or maintaining utility lines. Electric utilities, as part of their clean energy initiatives, are transitioning to hybrid-powered bucket trucks with the boom and bucket being powered by electric battery and the truck being powered by ICE.
2. Electric utilities have fleets of bucket trucks available to work on power lines. Courtesy: Xcel Energy
Lithium-ion battery systems are a preferred choice over lead acid batteries to power the bucket. This advanced lithium-ion auxiliary power system allows linemen to operate the bucket without running the engine all day and provides enough charge for nearly a full day of work, including powering the hydraulic lift system, power tools, and portable worksite power. The batteries also allow the trucks’ air conditioning, lights, and two-way radios to be operated while the engine is turned off. Without batteries, the lift’s hydraulic system would be powered by the truck’s engine, requiring the vehicle to idle during operation. On the way to and from job sites, the battery system is recharged from the engine alternator. It also charges in the garage without the need for specialized charging equipment.
These hybrid bucket trucks are more energy efficient as they cut down on hours of idling, thus reducing carbon dioxide emissions, noise, and engine wear. This system allows troublemen to fully shut down the truck’s engine while working on a line, making the trucks safer, quieter, more fuel efficient, and better for the environment. Also, elimination of engine noise makes working conditions safer, improves worker communication, and enables a quieter job site operation. A standard bucket truck’s engine uses about a gallon of fuel every hour that the bucket is in use. The new hybrid trucks are estimated to save about 30% on fuel. Reducing idling by only 15 minutes per day per vehicle, for a fleet of nearly 6,000 vehicles, saves about $1.2 million annually in fuel costs. It also reduces emissions by an estimated 1.3 tons of particulate matter, 21 tons of nitrogen oxides, 26 tons of carbon monoxide, and 3,800 tons of carbon dioxide each year.
California regulators are awaiting approval from the Environmental Protection Agency (EPA) for the Advanced Clean Trucks (ACT) legislation that will require vehicle manufacturers to sell a certain percentage of zero-emission trucks starting in 2024. This legislation will help California meet its climate goals and clean up the air in the state’s most disadvantaged and polluted communities. Electric utility bucket trucks are expected to be covered under ACT rule adoption. This has led to the recent emergence of the nation’s first all-electric bucket truck with two separate electrical systems providing power to the drivetrain and the lift.
From a technology perspective, lithium-ion technology is increasingly viewed as a compelling alternative to lead acid battery systems as it provides higher energy density, longer life, lower operating costs and maintenance requirements:
  • Lithium-ion batteries offer the highest energy density, enabling them to store and deliver more energy without taking up as much space as a lead acid battery.
  • Lithium-ion batteries provide 5 to 10 times more cycles than lead acid batteries.
  • Lithium-ion batteries lead to fewer battery replacements, lower charging costs, and minimal training.
  • Lithium-ion batteries support fast charging, longer runtimes, and opportunity charging minimizing idle time and maximizing productivity.
Lithium-ion batteries offer great savings compared to lead acid when you consider the Total Cost of Ownership (TCO). Though the upfront cost of a lithium-ion battery is higher, the return on investment (ROI) is attractive by achieving greater operational efficiency and lower TCO, with below listed op-ex improvements:
  • Increase in productivity resulting in 30% lower cost of operation—one hour charge time eliminates the need for battery changes and no equilibration charges with MH equipment.
  • Lowers electrical utility cost of charging by 20%—lithium-ion battery charging is 98% efficient vs. 80% efficiency with lead acid batteries.
  • Improved safety conditions for associates—eliminate battery changes and contact with battery electrolyte due to sealed “maintenance free” batteries with no watering.
  • Improved environmental conditions—eliminate lead from your environmental footprint.
  • Improved asset utilization with lift trucks—100% utilization with lithium-ion batteries (one battery per lift truck) vs. up to three lead acid batteries per lift truck (33% asset utilization with one battery in the lift truck and two in storage).
  • Lower lift truck maintenance costs—uniform power delivery extends motor life and reduces motor maintenance
In line with the op-ex improvements, using lithium-ion batteries achieves the following capex improvements when using MH equipment as well:
  • Capital cost avoidance—eliminate battery handling rooms, ventilation accommodations, eye wash stations, and safety gear.
  • Reallocate floor space—reallocate battery handing rooms to become a staging area, additional pallet rack, break room, or maintenance shop (at nominal $100 per square foot)
In addition to being clean and cost-effective, industrial electrification with lithium-ion advanced batteries and chargers enable Internet of Things (IoT) connectivity and telemetry. Smart, connected platforms pave the way for intelligent systems that can accelerate automation, reduce human intervention, and empower data driven decision making and analytics.
IoT connectivity enhances fleet management by remotely monitoring the assets and providing real-time visibility with the help of data acquired from these assets via an IoT gateway. IoT connectivity aids fleet managers in improving asset utilization and operations efficiency and enhancing the lifetime of the asset, thereby reducing both the op-ex and capex of their operations.
Jeffrey VanZwol is chief marketing officer for Green Cubes Technology, a Kokomo, Indiana-based designer and manufacturer of lithium power systems with offices around the globe. More info at www.greencubes.com.
