Salt River Project, Emerson Complete Hydropower Modernization Project
Close-Coupled Pumps for Low-Flow Applications
Moyno introduced the Moyno 2000 WA and WB close-coupled pumps designed for lower-pressure, lower-flow applications that do not require the full features and benefits of the Moyno 2000 GI pump. The Moyno 2000 WA (shown here) and WB models are ideal for municipal and industrial applications that require the transfer of highly viscous fluids and solids where a close-coupled configuration is preferred, but the robustness of a gear joint is desired. The Moyno 2000 WA pump features bearings integral to the adapter housing that support the radial thrust loads at the rotor/stator and a standard-size, keyed-gear reducer shaft. The Moyno 2000 WB pump features a traditional close-coupled design with thrust and radial loads supported by the bearings in the gear reducer, and no shaft bearings. (http://www.moyno.com)
