The new Moyno 2000 Model WA and WB pumps provide unmatched performance in a compact, close-coupled configuration. The close-coupled pumps are specifically designed for lower-pressure, lower-flow applications that do not require the full features and benefits of the Moyno 2000 G1 pump. They are ideal for municipal and industrial applications that require the transfer of highly viscous fluids and solids where a close-coupled configuration is preferred but the robustness of a gear joint is desired. The Moyno 2000 WA pump features bearings integral to the adapter housing that support the radial thrust loads at the rotor/stator and a sealed, gear-type universal joint drive train. The Moyno 2000 WB pump offers a traditional close-coupled design with thrust and radial loads supported by the bearings in the gear reducer. (http://www.moyno.com)
