Salt River Project, Emerson Complete Hydropower Modernization Project
New Moyno® 2000 Close-Coupled WA and WB Model Pumps Now Available
Springfield, Ohio – The new Moyno® 2000 Model WA and WB Pumps provide unmatched performance in a compact, close-coupled configuration. Moyno 2000 WA and WB close-coupled pumps are specifically designed for lower pressure, lower flow applications that do not require the full features and benefits of the Moyno 2000 G1 pump. The Moyno 2000 WA and WB models are ideal for municipal and industrial applications that require the transfer of highly viscous fluids and solids where a close coupled configuration is preferred, but the robustness of a gear joint is desired.
The Moyno 2000 WA Pump features:
• Bearings integral to the adapter housing that support the radial thrust loads at the rotor/stator
• Standard size / keyed gear reducer shaft
• Sealed, gear-type universal joint drive train
• Optimized rotor/stator pumping element geometry
The Moyno 2000 WB Pump features:
• Traditional close-coupled design with thrust and radial loads supported by the bearings in the gear reducer
• No shaft bearings
• Gear reducer output shaft designed with cross drilled pin holes for extended service life
Moyno, Inc., a unit of Robbins & Myers, Inc., is a leading manufacturer of Moyno® progressing cavity pumps, sludge pumps, metering pumps, sanitary pumps, mag-drive pumps, multiphase fluid transfer systems and grinders. Its worldwide multi-million dollar stocking distribution network serves a wide range of industries, including water and wastewater treatment, oil and gas, pulp and paper, specialty chemicals, pharmaceuticals, food and beverage, biofuels, mining, and petrochemical.
