ENFIELD, CT—Conval, a global leader in high-performance valves, offers Clampseal Blowdown Service Valves to provide necessary control for continuous or tandem boiler or turbine blow down and bottom blow-off service.
For continuous service, blowdown valves are available in ¾” through 4” sizes with butt or socket weld and flanged ends, in ASME/ANSI Class 900 through 4500. Standard materials are Low Alloy SA 182-F22, SA-182-F91 or SA-105. Specials are available upon request.
For tandem service, blowdown valves are available in ¾” through 4” sizes with butt or socket weld and flanged ends, in ASME/ANSI Class 900 through 4500. Standard materials are Carbon Steel A105, Low Alloy F22 or F91.
Clampseal blowdown valves are fully serviceable in-line using standard Conval tools. The valves feature a uniform one-piece gland, which eliminates the potential for stem damage from gland cocking. With leak-proof bonnet, the cartridge-style packing chamber allows rapid access to valve trim for inspection and maintenance. The pressure seal fixed backseat provides maximum valve integrity by ensuring a positive internal stop for the valve and stem and disc assembly. This also securely isolates the packing from line pressure when the valves is fully open, to increase packing life.
For more information, please contact Conval, 96 Phoenix Avenue, Enfield, CT 06082; telephone 860.749.0761 or visit www.Conval.com.
